Old 07-22-2019, 10:10 AM
robo92la robo92la is offline
Default Pro Tools 2019 CPU Spike Problems
So for the past few months I've had some frustrating problems randomly come about with my Pro Tools. I'll start from the beginning and try my best to include everything I did to troubleshoot the problem.
My Mac Specs:
MacBook Pro (15-inch, 2016)
High Sierra 10.13.6 (17G65)
2.6 GHz Intel Core i7
16 GB 2133 MHz LPDDR3
Intel HD Graphics 530 1536 MB
120 GB free out of 256GB
So, I believe I had been running Pro Tools 12.8.2, and my main third party plugins are Waves Gold, Soundtoys 5, and the Izotope Music Production Bundle. Now, I used to be able to run sessions with 20-30 of these high DSP plugins with no problems at all. But then suddenly, one day my Pro Tools started crashing from CPU Spikes after importing a friends Pro Tools project to mix. I'd get the -9173 error. And then eventually the problem stuck around even when starting brand new projects, they couldn't handle more than a couple plugins, and even when I'd restart Pro Tools without any plugins activated my CPU would be spiking with the -6101 error.
What I've done since is: Updated my Mac OS to Mojave, then updated my Pro Tools to 2019.6. I've uninstalled all my plugins and reinstalled. I downgraded back to High Sierra, starting with a clean OS again. I've reinstalled Pro Tools in a few different versions. I've tried dumping my preferences. I just really don't know where this bug is coming from. Any other ideas?
Old 07-22-2019, 10:35 AM
clivvy clivvy is offline
Default Re: Pro Tools 2019 CPU Spike Problems
this has been an ongoing problem for almost every body since 12.5 you also have to be aware of bad plugins because one bad plugin on a track can bring the whole session to a stop that happened to me a while ago it was a bass guitar from ample sound peaked my whole session right away so i replaced it with one of those really good basses from sample tank 3 and was able to play the session no more cpu spikes i do feel that Avid needs to take a look at this problem also and how to combat it!
Old 07-22-2019, 10:46 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi double check your power settings / optimizations and remove all your 3rd party plugins and look if the cpu spike still .
Does this happen with other sessions too ?
Also look for any app that can be running at startup in background on your OS .
Laste check your IO settings and make a default if necessary .
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 01-29-2020, 03:47 AM
Guilla Guilla is offline
Thread revival :
Do you think it has been ongoing only since 12.5 ?
Otherwise, just downgrading to PT 12.4 would solve the issue ? (that'd be too easy ).
By the way did the OP find a solution ?
2019.5 Ultimate on Mac not seeing iLok license (and other possible problems) Pete Gates Pro Tools 2019 21 05-19-2019 10:40 AM
PT 2019 same video problems garnoil Pro Tools 2019 12 05-12-2019 03:50 PM
Pro Tools 12.8 CPU Spike lucapane02 Pro Tools 12 42 03-03-2018 02:53 AM
problems with bounce to disk - extra noise spike? DJ FADE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-05-2007 01:56 PM
Audio spike problems with MBox 2... K-Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-01-2005 01:40 PM
