Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 10-17-2015, 05:08 AM
DylanM DylanM is offline
Default No sound at all when cable plugged into Pro Tools Express
Hi guys,
I've had an on-again off-again issue, where, if I plug my speaker cables into my Fast Track Solo box, there is no playback at all. This happened in the past, and then mysteriously stopped, and then started again. All my drivers are up to date, but this very frustrating, as it is nigh impossible to record with no playback. It is not my cables, as they work just fine when plugged directly into my PC sound card.
Does anyone have any suggestions?
Thanks a million in advance,
Dylan
Old 10-17-2015, 01:03 PM
Default Re: No sound at all when cable plugged into Pro Tools Express
A bit more info: I did a test - I exported MIDI drums from Guitar Pro (as I usually) do, Imported the MIDI into Pro Tools, and added the Addictive Drums plug in. All went smoothly as usual, but still, no audio from Media Player/VLC/Pro Tools. Anyway, bounced the drum track, plugged my speakers back into my PC, and played it, and it was fine. So the issue is with the box - the speaker cable makes a noise if I tap the jack, but the moment I plug it into the box, no play back.
Thanks again in advance!
Old 12-25-2015, 07:08 AM
warnutztheloser warnutztheloser is offline
Yea same here I get no sound thru my speakers only my Headphones...makes no sense
No sound recognised in Pro Tools Express AlistairH Pro Tools Express on Windows 0 08-26-2015 08:00 AM
cant hear my recording or sound in pro tools express proudmom Pro Tools Express on Mac OS X 1 06-10-2014 09:36 AM
No playback sound in Pro Tools Express ramadei Pro Tools Express on Mac OS X 3 10-31-2013 01:51 AM
Static Sound When Keyboard Plugged In??? Ransom macOS 2 12-27-2010 08:26 PM
Would the 888/24 sound better when plugged into 96 or 192 I/O ??? vudoo Pro Tools TDM Systems (Mac) 2 02-07-2002 10:33 PM
