Old 03-14-2014, 11:42 PM
eboyer eboyer is offline
Default Eleven Rack + Focusrite Scarlett 18i20
Hey guys,
New to the forums. After doing some research for the past couple days (and a lot of answers re-directing back to these forums) I figured I should sign up for an account and join the community.
I'm looking to build a little rack and love what i've seen with the Eleven Rack. My questions are:
- Does it make sense to pick up the Focusrite Scarlett 18i20 to have more inputs and plug the studio monitors directly in to it? Does it pair nicely with the Eleven Rack or is it redundant?
- Aside from that Ground Control Pro, are there any smaller boards / pedals that pair nicely with the Eleven Rack?
Thanks in advance, looking forward to jamming on some new gear soon!
Old 03-15-2014, 07:55 AM
nst7 nst7 is offline
Default Re: Eleven Rack + Focusrite Scarlett 18i20
The 18i20 has many more inputs and outputs than the Eleven Rack, so it's not redundant at all, assuming you need more inputs and outputs. Also, the 18i20 mic preamps will probably be better quality as well, so I would use that for anything where you're using a mic.
If you plan to use those together, your best option would be to have the 18i20 be your main interface, and hook up the Eleven Rack via digital Spidf into the 18i20, and just use the Eleven Rack for when you want to record guitar, and use the 18i20 for everything else.
Old 03-16-2014, 09:51 AM
In terms of the quality of sound going to the studio monitors, is there any difference between running them out of the Eleven Rack vs. 18i20? More inputs would be great, but I could probably hold off on that for awhile if that would be the only reason i'd take the dive for both.
How about pedals with the Eleven Rack?
Pro Tools 11 with Focusrite Scarlett 18i20? hermonmusic Third Party Interfaces 24 06-27-2015 08:53 AM
Focusrite Scarlett 18i20 ProTools crash. BurtonTrucking Third Party Interfaces 7 04-17-2014 11:30 AM
Scarlett 18i20 and USB 3 on Mac JCBigler Third Party Interfaces 1 11-09-2013 07:07 PM
Could you help me with this, please? - Calibrating a Scarlett 18i20 hermonmusic Getting Started 4 09-13-2013 08:33 PM
Mbox Pro 3 vs Scarlett 18i20 Help me decide! hermonmusic FireWire & USB Audio Interfaces (Mac) 11 08-09-2013 09:02 AM
