fet req: preview toggle to suspend preview
http://protools.ideascale.com/a/dtd/...79?submitted=1
I wish the preview soft-key wouldn't switch between preview and preview off but instead between preview and suspend preview. So preview off is a separate soft-key. Countless times I spend time to set a plugin and then hit preview unintentionally and there's no way back to what I just set. So I wish the hotkey would not toggle to preview off but suspend preview. This would at least be a poor man's simulation of what the Harisson automation works like with it's genius separation between read and write buffers. Plus a feature that recalls the last preview setting only for a selected track. Sort of the safety net after I turned off preview but I want to have the settings back again. http://protools.ideascale.com/a/dtd/...ck/108294-3779 Thanks!
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: fet req: preview toggle to suspend preview
There is a Eucon command called "Supend Preview". Its the same as command click preview with the mouse does.
I use it all the time! Look for it!
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
Ultimately the second request would be even better as it brings your last preview setting back after you have turned preview off. So probably easier to integrate and even more useful. Frank.
That is essentially a Pro Tools request. EUCON commands are coded directly into the software. IF the software doesn't do it, the software programmer can't create a EUCON command to do something different.
Since none of the Avid controllers operate in the way that you are describing, I doubt we'll this functionality (although what you are saying operationally makes a lot of sense) |
The request is essentially a suggestion to improve the PT/Eucon feature set. Frank.
...all I'm saying is that if Avid were to implement the feature request you are suggesting, it would also affect ICON (D-Control and D-Command) because it would be a change to the Pro Tools software...
Sure, why not? I know a lot of people who'd love an option to bring back the tweaks they just lost by turning off preview unintentionally. If it works on every controller it's even better. Frank.
I always wonder why some people want separate play and stop transport buttons, while others want the play button to toggle play/stop.
Guess that's why there is a preference for how the num pad works. I think this falls in the same paradigm. |
anyway to access Preview and Automation preview on PC or Edit | vudoo | ProControl, Control|24, Command|8 | 1 | 09-12-2009 06:49 AM |
can't ear audiosuite preview, no sound from preview -SOLVED! | sonuslab | Pro Tools M-Powered (Win) | 3 | 03-19-2008 12:51 AM |
audiosuite preview / workspace preview fixed in 7.4? | viaspiaggia | Pro Tools TDM Systems (Mac) | 10 | 10-11-2007 01:02 PM |
Preview | PTgeek911 | Pro Tools TDM Systems (Mac) | 2 | 01-08-2005 06:13 AM |
Preview? | Icemaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 11-27-2004 11:39 PM |
