Old 11-22-2009, 08:39 PM
ytass ytass is offline
Default Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on
Hello all,
This is just infuriating me. I have a clean Windows XP SP3 install, and have installed the M-Audio Firewire driver 5.10.0.5058, and then installed Pro Tools M-Powered 8.0
I am using a Firewire Solo. Windows sees the Firewire Solo and can use it (can play audio file in windows media player, and can listen out of speakers connected to FW Solo).
When I launch Pro Tools, it reaches the dialog box. "Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on".
This is ridiculous. What is going on here? I have already done a fresh install.This problem arose after I installed M-Powered 8.1. I decided to uninstall Pro Tools and go back to M-Powered 8.0, but that didn't help.
Please help!
I see so many other people have problems with M-Audio hardware. It really seems a joke that the product has such terrible performance and so many problems. Come on Digidesign and M-Audio. This should be simple - I'm wasting all my time trying to get my system up and running, where as this time should be spent on MUSIC!!
Make/Model: Gigabyte P55M-UD2 Rev 1.0
Operating System: Windows XP SP3
Processor: Intel i7 860
RAM: 4 GB Corsair 1333 MHz DDR3
FireWire: On board - Texas Instruments OHCI Compliant IEEE 1394 Host Controller, T.I. TSB43AB23 chip
Old 11-22-2009, 09:02 PM
Default Re: Unable to locate M-Audio Hardware. Make sure your hardware is connected and turne
I looked at the IRQ setup on my machine. The Firewire Solo is sharing IRQ 17 with the network card. So I disabled these other 2 instances:
* Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 6 - 3B4C
* Realtek PCIe GBE Family Controller
After disabling both devices, Pro Tools still did not see the M-Audio hardware.
Old 11-23-2009, 03:21 PM
DigiTechSupt's Avatar
I believe the current driver version is 6.0.1_5.10.0.5058. That's what came up when I went to the drivers page of the M-Audio website and selected Firewire Solo under XP with SP3. You should probably update to that driver.
Avid Audio Tech Support
Support FAQ
Old 11-24-2009, 12:14 AM
Default
I have updated the driver to 6.0.1_5.10.0.5058. Pro Tools still cannot find the hardware.
I have installed the Reaper DAW and it works perfectly with the M-Audio Firewire ASIO driver, and it was effortless, just like it should be.
Any suggestions - other than having to reinstall an OS, re-install Pro Tools etc etc?
Old 11-25-2009, 12:49 PM
I have been able to fix my problem. I had 2 different drivers installed on my system. One, was the driver that came with my install disk. The other was the 6.0.1_5.10.0.5058. I uninstalled the old driver and re-installed the new driver, and hey presto.
Thanks for your help.
'Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o roland342 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2012 09:01 AM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
Unable to locate Digidesign hardware. Make sure hardware is connected and turned on. qillster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-09-2011 06:49 PM
Unable to locate Digidesign hardware. Make sure hardware is connected and turned on.. qillster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-31-2011 09:08 PM
unable to locate M-Audio hardware. Make sure your hardware is connected and turned on joskraus Pro Tools M-Powered (Win) 13 05-13-2009 09:05 AM
