Go Back   Avid Pro Audio Community > Announcements > Technical Alerts
Old 02-12-2007, 10:50 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 7.3.1cs1 Updates for All 7.3.x Systems
Pro Tools 7.3.1cs1 Updates for all Pro Tools 7.3 or 7.3.1 versions for Mac OS X and Windows XP:
  • Pro Tools HD
  • Pro Tools LE
  • Pro Tools M-Powered
  • Pro Tools Academic
Available for download from the Pro Tools CS Updates Quick Link in the Support & Downloads section:
www.digidesign.com/support
In addition to the important fixes from Pro Tools 7.3.1, all Pro Tools 7.3.1cs1 updates for all platforms include the following fix:
Fixed: Adjusting Send Levels While Recording Audio Can Result in the Send Levels Resetting to "0" When Reopening The Session (Item #86186)
  • This would occur if no automation had been written on the Send.
Pro Tools HD 7.3.1cs1 for Mac OS X also includes the following:
Fixed: Disabling "Auto Input Monitoring" on Logic Pro 7.2.x (Direct TDM Configuration) Results In Random Error Messages (Item #85250)
  • This problem does not occur with "Auto Input Monitoring" enabled.
Pro Tools HD 7.3.1cs1 for Windows XP also includes the following:
Fixed: Moving OMF Video Clips On The TimeLine Could Result In an Access Violation Error Message (Item #85536)
  • This would usually occur a number of drag and dropped OMF video clips from the Workspace were moved around on the timeline. The message was "Could not complete the Region Slide command because Access violation occurred".
Administrator
HTML code is On
Pro Tools 7.3.1cs1 Updates for All 7.3.x Systems Avid Post - Surround - Video 0 02-12-2007 11:13 PM
Pro Tools 7.3.1cs1 Updates for All 7.3.x Systems Avid Pro Tools M-Powered (Win) 0 02-12-2007 11:11 PM
Pro Tools 7.3.1cs1 Updates for All 7.3.x Systems Avid Pro Tools M-Powered (Mac) 0 02-12-2007 11:09 PM
Pro Tools 7.3.1cs1 Updates for All 7.3.x Systems Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-12-2007 10:55 PM
Pro Tools 7.3.1cs1 Updates for All 7.3.x Systems Avid Pro Tools TDM Systems (Win) 0 02-12-2007 10:53 PM
