Old 01-25-2007, 09:02 AM
510man 510man is offline
Default D-verb Cuts All the Treble
I recently bought an M-box and I'm doing some mixdown work before mastering. It seems that every time I apply D-verb to a track, it significantly cuts the treble. I have to then re-EQ to try to get things sounding right again. However, if I do that, the snare (example) no longer sounds like it's in the band. It sounds like it's being played from next door. I don't have this problem when adding reverb on a digital or analog mixer so I believe it's contained in Protools. I'm applying the D-verb plug-in to the track. It may be that I need to assign it to a buss at unity and then send signal through it from the track?
Before I spend a great deal more time trying to figure it out I need to know if the D-verb plug-in just sucks and I'm trying to polish a turd or does it generally work reasonably well and I'm just doing it incorrectly?
Right now I'm pulling all the reverb out so the EQ is right and the drum is back in the band but it sounds thin. A little reverb would go a long way to fatten it a little but the EQ trade-off is not a good choice.
Any help is appreciated.
Old 01-25-2007, 09:10 AM
JMS40 JMS40 is offline
Default Re: D-verb Cuts All the Treble
Put the Dverb on an Aux track set to 100% wet and bus your audio to it. You should see much better results.
Old 01-25-2007, 01:31 PM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Try adjusting the HF CUT slider on D-Verb.
Old 01-25-2007, 08:50 PM
I almost never insert a verb plugin on the audio track(use an aux track and aux send to it). Be aware that Dverb defaults to -4db on the input.
Treble Booster Deny Eleven Rack 7 04-21-2011 01:55 PM
Treble Frequency way too high... f18mech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-09-2007 04:09 PM
Bass on left treble on right?? broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-02-2006 06:34 PM
Bass/Treble RichST999 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-04-2005 06:58 PM
Treble and Bass PAUL ALLEN General Discussion 9 11-13-2003 03:00 PM
