which software can you create drum tracks with
Im new to protools. I got the 002 with LE7 yestarday however I dont have a good computer to run it on yet. Im just making sure I'm ready to jump into everything. I have reason and sample tank with it so hopefully these will take care of drum tracks. So yeah, the question is, what program will I need to make drum tracks in protools...and is it as difficult as I think it's going to be?
Re: which software can you create drum tracks with
Stoneroses63
Personally, I prefer Reason's ReDrum, great flexibility, (Refills, Routing, Importing) and not a bad over all sound. ...and as a sidenote, this is only as difficult as you make it. Pro Tools DVD Reason DVD filosofem
Aaron Mulqueen - 001 HD Native |
Stoneroses63
filosofem
I agree, Reason's easy and the sound files are many, with good quality. It's Redrum is even good for a new user. Light something up, press play, and it will loop, making a sound each time it crosses the light. You'll see
BFD also gets noted on here as a really good program
Kryst |
so how do you use Reason Adapted to record to a midi track (or several separate instrument midi tracks, if possible) into PT?
I've been pencilling in and using sampletank. And i have used Reason for loops, but never actually knew how to record them as midi info. thanks!
TDub Digi002 R with Command 8 - PTLE 8.03 Intel Quad Q9550 Asus P5Q Pro Win XP 4GB |
Anyone? Can ReDrum be used to create midi tracks?
thanks
You don't record/create a MIDI track with reason adapted and/or redrum. You create the MIDI track in Pro Tools, and control the instruments in Reason. You could also create a MIDI track in reason, and control the instruments. Bottom line, the software doesn't create the MIDI, you do.
I have used some drum programming stuff, but I prefer to use samples I make myself (multi-velocity hits) and snap them to grid, make a quik loop, repeat, and do that for all the parts of the song (ie verse, chorus, bridge, ect..) It is a little more work, but your programming won't sound like everything else, because you are using your own samples
If I am in need of a quick groove though, I will use Redrum in Reason. Works fast, although a little stale.
Sign up for all things....AWESOME! Kris May the music move you |
TDub
Pro Tools Mix Window Create ten mono Instruments tracks Name them BD, SN 1-2-3-4, TOM 1-2, HH 1-2 and CYM Alt click the faders Insert Reason in all ten Instrument tracks Route ReWire from Mix L through to Channel 10 over all ten Instrument tracks Set MIDI I/O to ReDrum Channel 10 (or Channel 6, I can't remember off the top of my head) in all ten Instrument tracks via the Instruments View Control (View>Mix Window>Instruments) Pro Tools Edit Window Map all ten Instrument tracks, Octave 1 Note C1 through to A1 via Track Height>Single Note Saving as a Template, use Save As command ReDrum Flip (Tab) Reason Edit>Select All Devices Edit>Disconnect Cables Right click ReDrum's Channel 1 Output plug and select Hardware Interface Input 1 (This will result in a Stereo routing setup, disconnect that cable from Hardware Interface Input 2) Right click ReDrum's Output's 2 through to 10, connecting them to Hardware Interface Input 2 through to 10 Saving as a Template, use Save As command and navigate your way to your Pro Tools ReDrum Template Session Folder via the Save In window p.s. If you want to record these tracks to Audio, Buss the Output to the Input of seperate Audio tracks. (Mono Buss 1 through to 10) filosofem
Drum Tracks - which software/plugins??? | halipino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 03-09-2006 09:24 PM |
What are you using to create drum patterns/tracks | PastorBrian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 03-18-2004 01:26 PM |
Drum Tracks ... Software or Drum Module? | BRB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-05-2003 02:03 AM |
Need Mac software for drum tracks | jpan | Tips & Tricks | 2 | 12-01-2001 10:03 AM |
How to create quality DRUM TRACKS (midi/sampled) for a digital novice? | 6stringer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 08-26-2000 12:09 AM |
