Old 05-10-2019, 12:36 AM
Jamie Mac Jamie Mac is offline
Default 2019.5 OLED not responding properly
Bottom row of OLED's are not properly updating when switching from PAN to EQ or AUX.
It requires multiple button presses to display the correct function. (function is correct however, when touching or turning the knob the correct values change)
Any one else have this issue?
Old 05-11-2019, 04:14 AM
pavoni pavoni is offline
Default Re: 2019.5 OLED not responding properly
Sounds very similar to the problem I just had http://duc.avid.com/showthread.php?t=404596
Old 05-12-2019, 02:43 PM
ha2dorff ha2dorff is offline
+1
Old 05-12-2019, 04:50 PM
mattrixx mattrixx is offline
The top row is not behaving as it should in some cases I am finding also.
For example, sometimes, when I click "inserts" for a particular track, the OLEDs won't update, but the green "In" buttons do.... Have to click "back" and try again to update.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 05-13-2019, 05:38 AM
ACECOM ACECOM is offline
Same here. (S3+Dock+Mojave).
Old 05-14-2019, 02:52 AM
@tention @tention is offline
It's broken
SOUND!
Old 05-14-2019, 08:59 AM
EddieJones's Avatar
Can I ask....if you touch the knobs when the OLED's are displaying the wrong thing...do they change to the right display ? (Just want to make sure we are seeing the same thing)
Old 05-15-2019, 01:53 PM
S3:
This is a huge problem, so I really hope there will be a fix very soon.
I don’t know if it’s mentioned here, but after touching a fader and the volume is displayed, it do not return to normal view. To do that, I have to touch select.
Old 05-15-2019, 02:09 PM
EddieJones's Avatar
Originally Posted by ha2dorff View Post
S3:
What are your Fader Timeout Value settings set to ?
Old 05-15-2019, 03:16 PM
19.5.1 when?
OLED brightness RogerPaolo Avid S1, S3, Dock and Control App 21 01-26-2022 08:26 AM
OLED eq graph Macsearcher Avid S1, S3, Dock and Control App 9 10-26-2018 02:02 PM
Artist Mix - text on OLED is cut off at the top Bul Artist Series 2 10-20-2012 09:40 AM
mc mix second channel 's OLED missing ! klyg Artist Series 2 10-10-2011 10:14 AM
