Dolby Atmos Ceiling Speakers - Rear vs Front Ported Speakers
I am just about to complete the installation of a Dolby Atmos rig in a small room (tracklay and possibly premixing).
I am typing this a bit on the hoof here (I can give more details, dimensions and so on) but my query has to do with the ceiling speakers. I am about to install four Genelec 8020a's which are rear ported and due to the room dimensions (very high ceiling) I am not sure they are ideal. I am thinking of buying customised ceiling acoustic panels that allow the Genelec ceiling mounts to go through them. But I do have a few older 1029a's sitting in a cupboard which are are front ported. Any advice? |
Re: Dolby Atmos Ceiling Speakers - Rear vs Front Ported Speakers
This guy has done several rooms for me and it the best IMHO. Does a lot of composer friends in LA also. Big time and small time people. He is expensive, but is worth it if you need a good person. G http://bobhodas.com Also my friend Chris Huston, a legendary engineer and producer, is also a fantastic studio designer. Check out HIS portfolio. You can use my name Greg Ives to access him for a consultation. VERY easy to talk to. Maybe try him first. http://www.hustondesigngroup.com
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
This might not be a big issue. The HT RMU software has the option of setting bass management up. The frequency of that would really nullify the effect of the rear port.
If you are not going to use bass management for those speakers, the rear port will only become an issue depending on how close they are to the ceiling. There is some conflicting information on this, but recently I have seen more than a few acousticians mention that you can place the speakers nearly flush with the wall (or ceiling in this case) and be mostly fine. Randall Quote:
Randall Smith Audio Editor/Mixer Starz Entertainment Group Denver, CO |
Rear ported or front ported won't matter as long as give about 4" behind the speaker (and the genelecs can be mounted on threaded rod to put them on the ceiling.) Just remember that ports aren't directional "speakers" -- they operate at omni frequencies. You just need to make sure they are clear of obstructions so the air is not blocked off or create port noise (chuffing) from air turbulence hitting the rear surfaces. 4 inches is more than enough for any port to work fully.
However, the 8020 most likely is not close enough to any Atmos spec for output level or FR. If you have a high ceiling, that output level is going to be even more of an issue.
Regards, Paulo M MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura Protools Studio 2024.3 |
I am not bothered to hit the Dolby HT specs, not with this particular installation. I'd be moving this to a bigger room to do exactly that in about 9 months time. This particular room is a tad small.
I would be using the Genelec ceiling mounts, unless anyone can recommend a better alternative. All speakers will be calibrated by the SPQ card in the MTRX. There will be a preset ProMon preset with bass management. Good tip about the chuffing I'll think about that. |
This might be a good article to read for the person posing the question here:
Bob Hodas tunes studios around the world, from Sony in Tokyo to Abbey Road in London and all parts in between. https://www.tvtechnology.com/opinion...-in-the-studio
Omni headphone mix out rear port | subwoof | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-12-2018 10:59 AM |
How to get rear pan to follow front pan automatically? | bad jitter | Post - Surround - Video | 3 | 02-07-2015 12:57 PM |
Looking for advice on rear speakers for 5.1 | citysoundman | Post - Surround - Video | 8 | 01-23-2013 11:38 AM |
MBox 3 Pro problems with Front/Rear inputs | radiodef | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-16-2011 04:09 AM |
FireWire on the front vs. rear of my G5 | Deckard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 08-26-2009 09:03 AM |
