Old 07-13-2007, 09:26 PM
vjk vjk is offline
Default MIDI Drum Triggers
Can anyone tell me if it's possible to buy a Kick Pad for an electric/Midi drum kit and use it plugged directly into the MIDI-In port of my DELTA 1010LT with M-Powered (without a "brain" that's usually associated with such full kits).
I want to be able to play a miked real snare and hats with brushes while at the same time playing kick drum from the trigger pad into a Midi Track in MP-
.......do any of you have experience with such setups?......
thanks in advance...
PT MP 7.3.1cs3,Delta 1010LT,Yamaha MG16/4, AudioTechnica 20/20,Behrenger C2 Mics,Shure SM58,Windows XP Pro,P45G Chipset,P4 3Ghz,2Gb RAM
Old 07-13-2007, 10:00 PM
JrummerJ JrummerJ is offline
Default Re: MIDI Drum Triggers
Not going to work. You have to have a drum module or a dedicated trigger to midi converter. Triggers plug into the module or TMC, you adjust all the settings to get good triggering, select a midi note for each pad to send, and then connect the out of the module/TMC to the midi in of your 1010.
Take a look at the Roland TMC-6 or the Alesis Trigger I/O. You could also use just about any drum module ever made.
J
Old 07-13-2007, 11:33 PM
vjk vjk is offline
thanks Jrummer...I Googled both of them - have you used either of them yourself -
the TMC-6 has 6 inputs, 2 of which seem to be dedicated for the hats
the Alesis iO has 10 inputs, is cheaper and comes with BFD Lite (which I already have anyway)
So, if I got one of these units, does it mean I can get a Kick Trigger Pad, and then other pads as I want, and using the MidiOut of the unit, play the Kick sounds from BFD or EZdrummer or such, and record it as a Midi track?
Drum Triggers costas.themis The Drum Room 2 01-25-2012 03:12 PM
Drum Triggers, converting to Midi... JonnyGinese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-19-2005 02:10 PM
midi drum triggers SNAPPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-09-2003 07:13 PM
external MIDI drum triggers/pad Gingley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-09-2002 06:31 AM
drum triggers and sampled drum sounds SNAPPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-05-2000 11:11 AM
