Old 11-19-2020, 06:20 AM
omarNoCode omarNoCode is offline
Default 5.1 Output Bus I/O Assignments
Hi
I have recently set up a 5.1 studio to use with Unreal Engine, FMOD and Pro Tools Ultimate.
I have successfully managed to mix and monitor both Unreal and FMOD with the speaker configuration of L R C Lfe Ls Rs using the Saffire MixControl software of the Focusrite Interface and wanted to set up Pro Tools in the same way. I have attached the screenshot of the output I/O which matches the physical outputs to the speaker correctly but when I set up the bus configuration on the output it defaults to L C R Ls Rs Lfe and I cant seem to change it. In addition to that it defaults to mapping to the physical interface outputs of 1-6 and not 3-8 as I had set up in the output. I wonder if anyone knows how to change the bus assignment to correctly match the output. I feel like I am missing something basic here. Thanks in advance.
My setup consists of ProTools Ultimate 2020.3.0
Focusrite Liquid Saffire 56 Interface (Firewire interface running Saffire MixControl 3.7)
PC running Windows 10 Pro version 1909
Old 11-19-2020, 07:39 AM
reichman's Avatar
reichman reichman is offline
Default Re: 5.1 Output Bus I/O Assignments
Channel order inside Pro Tools can't be changed. Busses, tracks, meters, etc. will always be film order. So don't worry about your bus page. On your output page you can re-order the channels to the SMPTE order (or anything else). It looks like you have it right, but I would get rid of the unused outputs. You should now be hearing 5.1 coming from outputs 3-8. Is that not the case?
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 11-19-2020, 11:23 PM
EarHole EarHole is offline
7&8 are the defaults for the Cue on my system. Also, shouldn't stereo be 1&3 not 1&2? That's how mine is anyways.
Old 11-20-2020, 08:00 AM
reichman's Avatar
If you do Film order then stereo is 1+3, if you do SMPTE order, stereo is 1+2. Totally up to you how you want to patch your room outside of Pro Tools. I find SMPTE order much more convenient, but some interfaces don't allow it.
Nathaniel Reichman
Old 11-22-2020, 01:34 AM
I use a C24 and it's just how it's set up since PT works in Film Order.
Old 11-22-2020, 04:07 PM
Thanks for the responses, I actually made a sill mistake, and managed to fix the issue. I had actually re-routed everything in the Focusrite Mix Control Software so I just moved all the outputs over by 2 and that fixed the issue - everything is coming out of the correct speakers now!
Cheers
HTML code is On
12.7 Input / Output Assignments midnightrambler Pro Tools 12 2 01-10-2017 12:32 PM
[Q] How To Change All Output Assignments At Once? Jason Kardong Pro Tools TDM Systems (Mac) 8 03-13-2013 11:30 AM
output assignments on D-Command zakco ICON & C|24 3 09-07-2012 03:51 PM
Odd output assignments sw rec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-24-2009 05:20 PM
Multiple Output Assignments scottives Pro Tools TDM Systems (Mac) 4 08-02-2006 05:25 PM
