Old 06-15-2018, 10:16 PM
peoplevsme peoplevsme is offline
Default 003 rack + I/O Set Up solved
I was missing drivers (thought it would be automatic when installing PT) and I'm not sure how to delete this thread. The problem I was having:
Pro Tools does not recognize 003 rack. I am connected via firewire 400 to 800 cable, with 800 to thunderbolt adapter. The green link light is on. When I go to setup---> I/O, 003 is not listed. It lists APTAI/ in the space where it should say 003, then underneath shows built in microphone 1-2. 003 is also not listed in hardware setup. 003 is not available as an option for playback engine. When I look in System Information, the firewire device tree shows 003RACK in the firewire bus and thunderbolt tab recognizes the adapter.
iMac 10.9.5 2.7 Ghz i5 16 GB !600 MHz DDR3
PT 11.3.2
003 rack +
Old 06-28-2018, 06:37 PM
HeniousDelVon HeniousDelVon is offline
Default Re: 003 rack + I/O Set Up solved
id like to know myself I'm have the same issue, I just came over from using PT on a PC so this is new too me on a Mac... So I can't record at the moment
Branchement Eleven Rack avec Digitech GSP1101 Rack Daemonus Le Forum en Français 0 11-06-2014 03:46 AM
need help setting up protools 8 le with motif rack and trition rack(so newby to this) BeatBoy19 MIDI 0 06-01-2011 10:38 PM
Advice for Foot Controller and Rack/Case for Eleven Rack? udamann88 Eleven Rack 19 03-08-2011 06:24 PM
THE FOOT CONTROLLER for the Eleven Rack and any other rack modeler for that matter.. vkaxeman Eleven Rack 3 01-19-2011 04:13 AM
Major comp. problem - considering reverting to 002 rack instead 003 rack, good move? Tbassist4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-15-2009 04:20 PM
