Old 10-04-2020, 11:18 AM
noiseboyuk noiseboyuk is offline
Default Cleaning faders?
I have a sticky fader (the first one, naturally), often loses motor control and doesn't output any data until it hits the very top of travel and that usually kicks it back to life. Any use in exploring fader cleaning somehow? Back in the day Colclean used to work wonders sometimes on electrical stuff, but a) I don't know if it still exists or what its replacement might be, or b) if its safe to use on an Artist Mix anyway.
Obvs I can sent it for repair, but thought I'd check this first. Thanks!
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 10-05-2020, 06:48 AM
elicious elicious is offline
Default Re: Cleaning faders?
HTH...
ihatetyping
Old 10-06-2020, 01:17 AM
ALSTUDIOS ALSTUDIOS is offline
Hi
Had same issue after droping some coffee over the Artist Mix
After cleaning the surface, I sprayed WD40 into the rails of all the faders and let the testprogram run for some time. (You know - move faders up and down automatically). It worked afterwards as expected.
If you have really issues, open the device and clean the fadertrail (as well with WD40). Should work as well.
Otherwise.....by a new one...
Cheers
ALSTUDIOS REGENSDORF SWITZERLAND
[email protected]
https://sites.google.com/site/alrecordingstudio/
1pc AVID Artist Control and 1pc Euphonix MC Mix
Win11 64Bit, Cubase Pro 12.0.52
Old 10-06-2020, 06:21 PM
Neale Neale is offline
No.
No.
No no no no no.
WD40 is “water displacement formula #40”. It’s not a fader lube. If the fader is sprayed with WD40, it will appear to be better for a time... until it clogs up worse than it ever was when the dust bunnies grow with the WD40 stuck in there. Total pain to remove. Use proper fader cleaning materials from someone like CAIG or MG Chemicals. But before doing ANYTHING with fluid, try compressed air... you may fix it, but you may also make it worse if you blow the dust bunnies INTO the brushes instead of AWAY.
Proper way to do it is the disassembly from your first reply. Disassembly is a pain, but if you can get it back together and you don’t have spare parts left over, your unit should work like new again.
Old 10-07-2020, 02:33 AM
Marsdy Marsdy is offline
Originally Posted by Neale View Post
No.
No.
No no no no no.
Can’t help thinking that if you’re taking the unit apart you might as well just replace the fader with a new one. They’re like £38.
Dave Marsden
UK
Old 10-12-2020, 04:30 AM
Belated thanks to all. I know Colclean used to be very safe on electrical stuff (unlike WD40) - something like that is the only thing I'd risk trying cos I don't trust myself to take the thing apart and then have it back in one piece! Has no-one tried something like that?
I know Lee Electronics in the UK will swap out for a new fader, but its quite pricey and I'd be without the unit for a while.
Guy Rowland
Old 10-13-2020, 11:26 AM
MoPro's Avatar
MoPro MoPro is offline
As Neale said above... try the compressed air first!
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
EUCON Faders Off also sets Control app faders to -Inf? XJENSEN Avid S1, S3, Dock and Control App 1 01-26-2020 02:55 PM
Cleaning Control 24 faders? LDS ProControl, Control|24, Command|8 1 04-12-2017 07:03 AM
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 09:56 PM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 07:06 PM
Cleaning Faders and Pots R SCHLESINGER ICON & C|24 0 08-31-2002 08:07 PM
