Old 02-18-2021, 03:17 PM
Bytrox Bytrox is offline
Default Pro Tools gets smaller after playing a note on MIDI keyboard
Hey,
I downloaded Pro Tools this day because i need it for my diploma. I downloaded it normally from the Avid website and followed the instructions. Then i opened, and everything seemed to be ok. But when i played a note on my Alesis VI61 MIDI keyboard, Pro Tools gets smaller, and im unable to get it back to the normal size.
I reinstalled it one time, and Pro Tools changed back to the normal size, but when i played one note on the keyboard, it happened again.
Even when i make the Edit- and Mix-Windows bigger, the size of the stuff stays the same (like in the attachments).
Is there anything i can do? I wrote the stuff i use in my signature, i hope you can read that. It would be nice if anyone can help me
My specs:
  • Razer Blade 15
  • Intel Core i7 (10th Gen, 16GB RAM)
  • Windows 10
  • Pro Tools (Stndard version)(2020.12)
  • Interface: Steinberg UR242
  • Keyboard: Alesis VI61
Old 02-18-2021, 04:20 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Pro Tools gets smaller after playing a note on MIDI keyboard
Try Maximizing PT.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-18-2021, 04:28 PM
Originally Posted by The Weed View Post
Try Maximizing PT.
I already treid that. Same result...
My specs:
  • Razer Blade 15
  • Windows 10
Old 02-19-2021, 04:31 AM
It seems like the Alesis may be sending out strange messages. Download the free MIDI-OX utility program and run it with PT shut down. Try the different controls and such on your keyboard and see if it's sending out the correct message for the control being used.
Old 02-19-2021, 04:50 AM
Thanks for the help! What do you mean with PT shut down?
My specs:
  • Razer Blade 15
  • Windows 10
Old 02-19-2021, 04:53 AM
ChuckS ChuckS is offline
It looks like you are scaling your display. Rather than use a scale percentage, set the percentage to 100% and change the Display Resolution in Settings --> System --> Display.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 02-19-2021, 05:03 AM
Southsidemusic's Avatar
He means what he wrote, Run the Midi Ox with Pro Tools shut down, Not launched, only computer started and no other programs running.
You will get an answer quickly with the OX and go from there.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 02-19-2021, 05:46 AM
Could be but from the description he thinks it's due to something coming from his Alesis.
Old 02-20-2021, 05:35 AM
Too bad the OP didn't enlighten us on the resolution of the problem. Excuse the pun.
Old 02-20-2021, 11:30 AM
I don't think he solved it or at least didn't post about it here. To me that usually means it was a pilot error that he's too ashamed to admit to.
MIDI note Latency . . . live keyboard playing is a "little behind" The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-09-2012 05:33 PM
Pro tools 10.1 Midi plays keyboard note with same intensity when I dont want it to shamanrock Windows 3 02-22-2012 08:44 PM
Pro Tools + 61-note MIDI Keyboard = missing low notes! k0000 MIDI 12 03-04-2011 09:29 PM
Pro Tools + SSD + 61-note MIDI Keyboard = missing low notes! k0000 The Drum Room 9 03-04-2011 09:19 PM
Pro Tools 8 + 61-note MIDI Keyboard = key change? k0000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-04-2011 08:43 PM
