Old 02-25-2020, 03:34 AM
Default Re: Local Storage on Pt First
Don't hold your breath if First gets people buy PT it works as intended
Old 02-25-2020, 03:37 AM
Netmania Netmania is offline
In my case it did and i don‘t regret 🙂
Old 06-01-2020, 05:59 AM
harry smit harry smit is offline
Hi Netmania,
Would the below workaround be an idea? I did some basic tests only... Worth giving it a try.
Store the complete Pro Tools folder (that is including subfolders and files) on a different drive and use mklink to make a shortcut as if the files were still in your Documents\Pro Tools folder.
OS: Windows 10 Pro x64, build 1909.
Pro Tools First 2019.6.
ASIO4ALL v2.14
FIRST.
I moved the complete Pro Tools folder and its contents (around 1 GByte in my case) from Documents\ to a folder on a preferred data drive (E:\bin\).
I assured that the Documents folder did not contain any Pro Tools folders or files anymore.
The new folder is then now E:\bin\Pro Tools
SECOND.
I opened CMD in Administrator Mode and entered this mklink symbolic link command (the quotes are needed because of the spaces in the folder names):
mklink /d "C:\Users\USERNAME\Documents\Pro Tools" "E:\bin\Pro Tools"
CMD should then come back with:
symbolic link created for C:\Users\USERNAME\Documents\Pro Tools <<===>> E:\bin\Pro Tools
In the Documents\ folder I found the by mklink generated folder Pro Tools again but then as a shortcut.
I started Pro Tools First 2019.6 and it worked OK.
BTW. I do not sync too much to the AVID cloud at the moment since due to COVID-19 the servers over there are a bit crowdy... (untick the green Backup to Cloud bullet).
Good luck
Harry
Old 06-01-2020, 08:31 AM
Hi Harry,
thanks for your solution. Since I shifted to Pro Tools Full there is no need for me to go that route. By the way - meanwhile I bought a mbox2 for dirt cheap and got Pro Tools 8 LE full version without subscription. It makes fun to see how easy things can go - plug in my Mbox, fire up Pro Tools, rename and move folders etc. everything works. No Cloud, no internet, very, very fast and stable. I payed 100 Quitt for Mac mini, Mbox 2, Logic express 9 and Pro Tools 7 and 8 LE.
Pro Tools First is 8 months after release of Catalina not compatible, that's a shame in my opinion for AVID - since they loose a lot of starters that buy a new MacBook Air 2020, MacBook Pro 13 2020, MacBook Pro 16 2019, Mac mini 2020,
and Mac Pro 2019. No one with a Focusrite, M-Audio or many other Audiointerfaces who wants to Try out Pro Tools First is able to start.
Sorry Harry, bit off topic Have a nice day and stay safe.
iLok USB 2 Not Showing In Local Puddles98 macOS 1 12-12-2015 04:46 AM
Local i/o From S3 amesiandy Avid S1, S3, Dock and Control App 2 11-18-2014 10:44 PM
Online or local backup ? chrisdee General Discussion 5 03-01-2013 04:39 PM
Simple Idea for a Local Workgroup Storage Server? spicyitaliano Pro Tools TDM Systems (Mac) 10 09-28-2007 06:12 PM
Sending Local Off Dirk Reinking MIDI 0 09-08-2007 08:19 AM
