Old 10-24-2002, 06:36 AM
bigthinka9 bigthinka9 is offline
Default No Sound-help!! After deleting Digisetup, PT prefs and DAE prefs
I deleted those files in an effort to clean up a problem. Now I can hear anything. Any advice?
Old 10-24-2002, 06:37 AM
Default Re: No Sound-help!! After deleting Digisetup, PT prefs and DAE prefs
I meant CAN'T HEAR ANYTHING.
Old 10-24-2002, 06:42 AM
FajitaTone FajitaTone is offline
You did re-assign outputs, and maybe check your i/o setup.
[img]images/icons/grin.gif[/img]
Ray Trujillo
Freelance Audio Engineer
Old 10-24-2002, 06:51 AM
Do you mean re-assign them in the I/O setup?
(I did check the I/O setup)
Also, when I play the track, the lights don't come up on the 888. Is this part of the problem?
Old 10-24-2002, 06:53 AM
putney2 putney2 is offline
More info needed.
System
Computer
HD or Mix
888 or 192
Old 10-24-2002, 06:56 AM
System
Computer
HD or Mix
888 or 192
We have a mix plus system.
G3 computer
888 interface
Old 10-24-2002, 07:41 AM
Make sure that you selected the right interface in the i/o setup [888 or 888/24] and make sure you've selected the right card and port [A / B]
Check the cable from the 888 to the mix card.
With your computer turned of, can you pass audio through the 888 as a stand alone device ? If not suspect the 888. Do any lights show on the 888 ? If not, 888 power supply.
Do the cards pass the Digi Test ?
These are good starting points.
deleting prefs and now Protools wont boot ChrisMac Post - Surround - Video 10 05-21-2013 07:22 PM
Mbox Pro not in Sound Prefs TylerHawley macOS 0 03-15-2012 12:16 PM
Deleting DAE Pref and Digidesign Prefs not working farmersmarket 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-21-2008 10:18 AM
Folders deleting prefs etc rickf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-09-2006 03:58 AM
Digisetup, DAE Prefs Folder and Pro Tools LE 5.0 p audiotracker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-13-2003 03:42 PM
