Old 10-07-2015, 09:48 AM
TheEdster75 TheEdster75 is offline
Default Recording all Computer Audio for a Podcast
Ok, mostly I do Audio Production, but I've recently gotten into Podcasting with a friend of mine.
I have a 2013 27" iMac, running Pro Tools 11, with an MBox Pro (3rd Gen) which is the larger Audio Interface that is 400 Firewire. I am using the Firewire to Thunderbolt Adapter. Which by the way works great!!
So I am wondering, cause right now I am doing everything through Screenflow and exporting the Audio.
With my set-up, is there anyway to record all computer audio through Pro Tools 11 using the MBox Pro Interface?
Thanks!
Edward Fenley
"Either learn to endure, or hire a bodyguard." ~ Bruce Lee
Old 10-07-2015, 10:06 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Recording all Computer Audio for a Podcast
Can you run a cable from the audio out into the Mbox? That's probably the easiest way with the fewest possible issues.
Brian
Windows 10 Pro 64 Bit
Pro Tools 2020
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Instagram
Old 10-07-2015, 10:28 AM
Everything on my iMac connection wise is either UBS 3.0 or Thunderbolt. I guess I can ask the guys in the Pro Audio at Guitar Center, if adapters are made for that. I have to go there at lunch anyway...
Edward Fenley
Old 10-07-2015, 10:37 AM
Sardi Sardi is online now
No, Benoni means run the audio line out of your iMac to an input on your MBox.
Just grab a stereo minijack to dual quarter inch and away you go.
Old 10-07-2015, 10:44 AM
You can connect the iMac using analog audio to the interface, but your iMac also has S/PDIF optical (TOSLINK) digital output on a mini-TOSLINK connector inside the audio/headphone socket. If your interface has TOSLINK input just get a suitable cable. If your interface has S/PDIF on a coaxial input get a S/PDIF TOSLINK to coax converter. There are other ways of doing this but good old simple hardware works reliably.
If you are asking folks at Guitar Center questions you have already lost...
Old 10-07-2015, 10:51 AM
sw rec sw rec is offline
"If you are asking folks at Guitar Center questions you have already lost..."
My experience as well.
Old 10-07-2015, 12:46 PM
Well, Darryl...
I don't have a S/PDIF on a coaxial input..
Here is a pick of the front and back of my interface.. Any ideas?
http://www.jeejuh.com/images/blog/mbox-3-pro-back.jpg
Edward Fenley
Old 10-07-2015, 12:51 PM
Would this work from my iMac Toslink to my Aux Inputs to my interface?
http://www.amazon.com/DBTech-Digital.../dp/B009AGTC3Q
Edward Fenley
Old 10-07-2015, 12:53 PM
mesaone mesaone is offline
How I feel when I'm in GC and they try to steer my purchases.
Back to the topic at hand, the best way to go about this (if you have the option) is to do a digital loopback.
For example, my interface has a routing matrix which allows me to run any number of outputs back into unused inputs, without cables. I can then set the audio input of my screen capture software to the pair of inputs I routed back to, and it will capture along with the video. If I don't need it to sync (or if I need to capture audio only) then I just run an instance of TotalRecord in the background. Audacity is a good choice for this, too.
Since you have an MBox, it may be possible to set computer output to soundflower, then record or monitor directly with a track in Pro Tools. You would have to have the system audio play through the mac's built-in output to avoid feedback loops (if it were set to MBOX, you would get feedback).
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 10-07-2015, 01:09 PM
Well, Darryl...
Mbox 3 Pro has S/PDIF inputs and outputs on a coaxial input and output via the adapter cable that comes with it. So you would need a S/PDIF optical to coax converter.
Soundflower is another option but hardware works reliably.
Recording computer audio with 11R and Protools. Gerry White Eleven Rack 4 04-14-2012 08:57 PM
Recording Podcast with MBOX 3, 2 Microphones (2 Hosts) and 1 Skype caller JimmyMcV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-05-2011 11:51 PM
MP3s For Podcast marindakim Post - Surround - Video 4 12-02-2005 09:39 AM
Home Recording PODCAST IHR General Discussion 3 10-06-2005 10:07 PM
Pro Tools LE Podcast Shan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-13-2005 09:14 PM
