Old 01-29-2020, 12:07 PM
avernon82 avernon82 is offline
Default Re: Eucon instability
ok, would love some help getting my system stable as well
I don't see how to set static IP addresses on the Fire HD10s, I don't see the option in the settings.
Old 01-29-2020, 12:19 PM
mixboy bob mixboy bob is offline
https://www.groovypost.com/howto/cus...ndle-fire-hdx/
http://www.robburrell.com
PTHD Ultimate/Eucon (latest betas) / Mac Studio Ultra 128GB RAM / Aja T-Tap / Sonnet M.2 4x4 PCIe 8TB / Focusrite 16Line / MTRX Studio / UAD Octo / 32 channel S1 & Dock (5) 2019 Fire HD 10 / Dolby Atmos 9.1.4 /Mastering Suite / 13.0 Sony 360RA
Old 01-29-2020, 12:37 PM
There is nothing in that link about setting static IP settings in Amazon Fire HD
Old 01-29-2020, 02:26 PM
New link posted... that was weird.
Old 01-29-2020, 02:30 PM
Lynn Gräber Lynn Gräber is offline
You have to find the MAC address of each or your Fire HD, then reserve an IP address using those MAC addresses under your router preferences. This process can be a bit different depending on the router, you may just have to poke around your settings.
I don't have my router or Fire HD's with me at the moment, but I remember the MAC addresses being kinda hidden in the wifi settings on the Fire HD's.
  #16
Old 01-29-2020, 03:04 PM
Thank you so much! Set my tablets to Static...fingers crossed
  #17
Old 01-29-2020, 04:49 PM
no luck, still dropping out
  #18
Old 01-30-2020, 10:12 AM
EddieJones's Avatar
EddieJones EddieJones is online now
I just want to double check this is off
  #19
Old 01-31-2020, 02:09 AM
Clemens Becker Clemens Becker is offline
Hi, similar problems with unstable setup.
i use 2 S1 with Fire HD pads, one Dock with an iPad Air. Is there somewhere a Manual how to setup all 6 items with an static IP? Just couldn`t find any, Thanks
Clemens
  #20
Old 01-31-2020, 09:15 AM
So I don't know how to set the surfaces to a static IP, but for the FireHDs, go to your wifi connection, tap on it. There's a little pencil in the upper right corner, tap on that. Tap on Advanced options. Scroll down in that window to find where you can chose between Static and DHCP. Choose Static, then enter your desired IP address. the iPad is better documented online, so do a google search for that
EDDIE
hands free Alexa is turned of
Instability Issue munchman Eleven Rack 5 01-29-2018 03:00 PM
SSD 4 and instability nozzles macOS 2 01-23-2012 07:28 AM
Instability of 7.3 midi sordino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-13-2007 05:35 AM
General instability in PT7, looking for help. deafguy Pro Tools TDM Systems (Mac) 12 04-30-2006 11:02 AM
Bluetooth and Instability? Mount Royal Pro Tools TDM Systems (Mac) 1 09-09-2005 05:14 AM
