Old 12-29-2008, 06:08 PM
spike.mk spike.mk is offline
Default MBox - importing session data, missing audio!?
I have an MBox2, I am trying to import audio from a lager session (there are about 70 tracks but im only importing about 15) and when it imports, it imports everything but the actual audio files. It puts the files in the regions list but not in the track. So I loose the placement of these wav files on the tracks and loses sync. I am importing from an 88.2 session, does that have something to do with it? I don't think it shouldn't. Any help, or just yelling at me for being an idiot is appreciated heh. Thanks!
- Spike
Old 12-29-2008, 06:19 PM
tracktensionrecords tracktensionrecords is offline
Default Re: MBox - importing session data, missing audio!?
consolidate the audio tracks ,from start point to the end , then bounce them out as stems. then import audio into your new PT session.
www.myspace.com/tk2372
Old 12-29-2008, 06:27 PM
Well the thing is I am stuck with just the MBox and I am not even able to open up the original session because its in 88.2. Otherwise I would have no problem
Old 01-07-2009, 05:41 PM
[email protected] frank.lawrence@hklaw.com is offline
I'm having a very similar problem. My friend sent me an email with his session as an attached file. I downloaded to my desktop, and then used "import session data" and created new tracks. The session opens, all the tracks are there, but there is no audio at all.
During the import I get several messages:
(1) "original disk allocation for this session cannot be used. Check the disk allocation window to see what has changed";
(2) "your I/O setup has changed since the last time this session was saved. Check the I/O setups window to see what's changed";
(3) "Missing Files -- 33 audio files, 1 fade file, 0 video files are missing"
(4) my friend is using PT LE 7.4.2f109 and I'm running PT LE 7.3.1.
Any suggestions?
Old 01-08-2009, 08:11 AM
DigiTechSupt's Avatar
I think the sentence in bold spells out the problem - if your friend sent you ONLY the session file, then that would explain the missing audio. He would need to send you the audio files (presumably in the audio files folder on his record drive) for them to show up in Pro Tools.
Avid Audio Tech Support
Support FAQ
Old 01-08-2009, 08:12 AM
- Spike
Can you give us more details about your system and the session? What version was it created in? Which version are you running? What sample rate is your session? Did you check the option to SRC upon import? How many tracks are currently in the session?
Support FAQ
Old 01-08-2009, 08:42 AM
wolfskin wolfskin is offline
Exactly. I'd bet that the entire session may be too large to email anyway. Your best bet would be to have your friend convert the session to 44.1k and send the entire session directory to you on DVDs.
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2
AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM
www.wolfskinrecords.com
www.voodoopilot.com
importing session data paulodegaard macOS 0 12-03-2011 11:16 AM
Audio files are missing when i import session data ... montreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 02-25-2010 12:50 PM
Importing session data 100below Pro Tools TDM Systems (Mac) 0 05-27-2009 10:04 AM
importing session data PATofNAVAR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-11-2007 07:24 PM
Problems importing audio, session data, etc. essay Pro Tools TDM Systems (Mac) 0 09-12-2006 10:18 PM
