Opening Pro Tools 9 Projects in Older Versions
Hi, I was wondering if anyone could help me.
I'm working on some projects for University, the problem is that I'm running Pro Tools 9 at home and my lecturers are running Pro Tools 8 LE. Is there a way for me to save my projects so that they can open them when I hand in my work? Cheers |
Re: Opening Pro Tools 9 Projects in Older Versions
PT9 sessions open in PT8LE no problem, just watch the track counts, you can have more in PT9
PT 9 sessions should open fine in PT 8 LE, but any new features in PT 9 will be disabled in PT 8 LE. The main one to keep in mind would be delay compensation, as having this disabled could really change the sound of your mix. I would try to make everything sound the way you want it with delay compensation disabled in PT 9 by using Time Adjuster plugin or by nudging your tracks to manually compensate for the delay, then do a Save Session Copy In to make sure the session is self-contained, before handing them in. If you are on a different platform that your instructors (i.e. Mac vs PC) then make sure to check the Enforce Mac/PC Compatibility setting in the Save Session Copy In window. If you are not using delay compensation in PT 9 then disregard that part of my post.
HTH Oh, and the track counts... good point Barakka!
Scott Gatteño Last edited by originalscottyg; 03-09-2011 at 08:07 AM. Reason: addition |
I've been running without delay comp so that should be fine. I didn't realise it'd be that easy.
Question about an older Mac Pro and possible older versions of Pro Tools HD | wolfman_rob | Pro Tools TDM Systems (Mac) | 13 | 07-21-2013 01:29 AM |
Plug Ins for Older Versions of Pro Tools LE | mgnyhc1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-17-2009 09:25 AM |
Opening older session versions in 8 | tomdiek | Pro Tools TDM Systems (Mac) | 7 | 12-30-2008 05:48 PM |
Opening HD 7.4.2 Sessions on Older Versions | Lumin | Pro Tools TDM Systems (Mac) | 2 | 10-30-2008 02:13 PM |
opening older versions of protools in v/ 6.9.2 | ahead1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-09-2005 09:44 AM |
