Pro Tools 9.02 crashing while loading certain sessions
I have a 2 week old PC running Windows 7 (SP1) with a fresh install of PT 9.02 & an M-Box 2 mini. All was working fine until when some (not all) saved sessions crash during loading giving a 'Pro Tools Application Has Stopped Working' message.
This occurs as the session is loading the various settings but I haven't been able to pin it down down to a particular plugin / type of track. A lot of the sessions were created on my old PT8/Windows XP PC but some have been edited and re-saved in PT9. I have not installed anything new in the last few days that I can attribute this problem to. So far I have done all the obvious / recommended things like deleting setting & databases, updating drivers etc. and have done a PT 9 uninstall / reinstall. I really don't fancy uninstalling / reinstalling all the plugins or doing a windows reinstall so anyone got any ideas? My Sandra is here: Computer Model : Gigabyte P67A-UD3-B3 Workgroup : WORKGROUP Host Name : Coolermaster User : Michael Processor Model : Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Speed : 3.9GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : Gigabyte P67A-UD3-B3 BIOS : Award (Phoenix) F2 02/22/2011 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR3 Chipset Model : Intel Core (Sandy Bridge) DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 8GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : Corsair CMX8GX3M2A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMX8GX3M2A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce GT 430 (96 SM5.0 1.4GHz, 1GB, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GT 430 (96 SM5.0 1.4GHz, 1GB, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce GT 430 (96SP 2C 1.4GHz, 1GB) Compute Shader Processor : NVIDIA GeForce GT 430 (96SP 1.4GHz, 1GB) CUDA Processor : NVIDIA GeForce GT 430 (96SP 2C 1.4GHz, 1GB) Storage Devices WDC WD10EALS-00Z8A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (E:) WDC WD10EALS-00Z8A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (D:) C300-CTFDDAC128MAG 128GB (SATA600, 2.5", SSD) : 119GB (C:) Generic 2.0 Reader -0 (USB) : N/A (G:) Generic 2.0 Reader -1 (USB) : N/A (H:) Generic 2.0 Reader -2 (USB) : N/A (I:) TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices Audio (E:) : 932GB (NTFS) @ WDC WD10EALS-00Z8A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Documents (D:) : 932GB (NTFS) @ WDC WD10EALS-00Z8A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) System Reserved : 100MB (NTFS) Hard Disk (C:) : 119GB (NTFS) @ C300-CTFDDAC128MAG 128GB (SATA600, 2.5", SSD) Removable Drive (G:) : N/A @ Generic 2.0 Reader -0 (USB) Removable Drive (H:) : N/A @ Generic 2.0 Reader -1 (USB) Removable Drive (I:) : N/A @ Generic 2.0 Reader -2 (USB) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte Cougar Point LPC Controller LPC Legacy Controller 1 : T2 87-28 Audio Device : Giga-Byte Cougar Point High Definition Audio Controller Audio Device : ZOTAC International (MCO) GF108 High Definition Audio Controller Audio Codec : nVidia 0014h Audio Codec : 1 0001h Audio Codec : 1 0001h Disk Controller : Giga-Byte Cougar Point 6 port SATA AHCI Controller Disk Controller : 25365 88SE9123 SATA-600 Controller USB Controller 1 : Giga-Byte Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Giga-Byte Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Giga-Byte uPD720200 USB 3.0 Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Media Player : () Media Player : () Media Player : () Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 6.7 |
Re: Pro Tools 9.02 crashing while loading certain sessions
You could try creating a new session, then importing the tracks one by one from your old session and see if a plugin or something is causing PT to crash.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
cwsand Thanks for the suggestion. I tried import session track by track and Strike seems to be the culprit. After uninstalling it all the old sessions open ok (well without drums!).
I was running Strike 1.5 in Pro Tools 9.02 on Windows 7 (SP1) 64 bit. Anyone else had this problem or can think of a work around? I have 13 tracks recorded for an album and strike it on 10 of them. |
Turns out I was missing out one the 3 preferences you are meant to delete / thrash.
This link really is a must for all PT9 probs: Delete Digidesign Databases and Preferences : http://avid.custkb.com/avid/app/self...nd_Preferences |
Sessions Not Loading! Pro Tools LE | Awesomeworld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-16-2010 04:06 PM |
AutoTune 5 Crashing Pro-Tools loading older sessions | KingFish | Pro Tools TDM Systems (Mac) | 1 | 12-16-2010 02:19 PM |
Dverb bogging down computer when loading 7.4 sessions into Pro Tools 8? | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-26-2009 12:29 PM |
Pro Tools M-Powered 8CS3 crashing while loading plugins? | vseanv | Pro Tools M-Powered (Win) | 1 | 07-30-2009 09:29 AM |
DigiReWire crashing pro tools on loading | crizdee | Pro Tools TDM Systems (Mac) | 0 | 01-25-2005 09:28 AM |
