Old 03-13-2007, 07:29 AM
Curtis Marolt Curtis Marolt is offline
Default Replace Region BUG in 7.3.1 DV Toolkit
When I use "replace region" in shuffle mode with files of different lengths, the regions in the track DO NOT snap together. If I use a shorter region to replace a longer one, there will always be a gap at the end of the file before the next region.
I have tried every combination of settings just to be sure something hasn't changed.
This has functioned properly on all versions (5.1 through 6.9) that we run here at our studios.
I am doing concatenated VO editing and this function is imperative for efficient editing.
Had I known that this was an issue, I would have not upgraded.
Am I doing something wrong? Any solutions/fixes on the horizon?
Curt
PTle 7.3.1, DV Toolkit, Mbox 2 Pro, Mac Pro Tower, 10.4.8
Curtis
Old 03-14-2007, 12:27 PM
Default Re: Replace Region BUG in 7.3.1 DV Toolkit
Any Assistance?
Curtis
Old 03-15-2007, 09:17 AM
Help??
Curtis
Old 03-16-2007, 02:17 PM
Is anyone home??????????????????????????????????
Anyone?
Digi?
Curtis
Old 03-16-2007, 02:25 PM
DigiTechSupt's Avatar
I'm going to look into this, but won't be able to until Monday.
Just so you know - we're not always on the DUC and can't respond to every post. If you need an answer quickly, it's always best to use either the Tech Support Request Form or contact tech support by phone.
Avid Audio Tech Support
Support FAQ
Old 03-20-2007, 08:06 AM
I appreciate the response.
In my experience, I have received better and timelier responses through the DUC as opposed to tech support directly.
Thanks,
Curtis
Old 08-16-2007, 09:29 AM
This problem still exists on 7.3.1cs4.
Will there be a fix? This is a huge log-jam in our departments throughput. We are starting to roll out 6 new Mbox2 pro PTle7.3.1 machines. This is a feature that we absolutely need.
Please help. I will try tech support again.
Curtis
Curtis
Old 08-19-2007, 11:52 AM
Here is Tech Supports answer....
"Hi,
We are aware of this behavior and hoping to resolve it in a future
release. Thanks for you patience with this issue.
Best regards,
Digidesign Technical Support"
Oh well?
Curtis
Old 08-19-2007, 03:32 PM
Craig F Craig F is offline
being that this is DVTK you might want to mention this in the Post section
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 08-21-2007, 01:50 PM
Good idea. Thanks
Curtis
Replace Region BUG naughty G Pro Tools TDM Systems (Mac) 1 05-13-2009 04:50 PM
Using Replace Region — need expert Dan Pinder Tips & Tricks 9 12-16-2005 11:01 PM
6.9 Mac Replace Region Bug?? Borg Pro Tools TDM Systems (Mac) 7 07-05-2005 08:17 PM
Region Replace webby Tips & Tricks 4 06-09-2005 09:44 PM
Replace all instances of a region d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-15-2003 11:30 AM
