Old 10-02-2019, 09:30 PM
Jeff ONeil Jeff ONeil is offline
Default 2018.7 sudden issues
I'm running El Capitan on a Mac trashcan with Pt's 2017.7.0
I do VO work and I tend to keep a system going so long as it's working. Today I was tracking to a video and kept getting error windows warnings about needing more more cache. I set it to 12GB and PT's kept crashing in that session. I've never had tis error message happen before. Wondering if this is connected to the IOS13 issues? I created a new session without the video - just the music track and guide vo and it worked fine.
Wondering if anyone else is seeing this in older versions of PT's?
Thanks, Jeff
Old 10-02-2019, 09:41 PM
Sardi Sardi is offline
Default Re: 2017 .7.0 sudden issues
There was no PT 2017.7.
They didn’t adopt that naming scheme until 2018.
What version are you actually running?
Old 10-02-2019, 09:44 PM
My mistake, been a long day! I'm running 2018.7.0
Old 10-03-2019, 05:14 AM
Jeff:
I see you're running El Crapitan which is the worst OSX Apple has ever foisted on the public. Suggest going to High Sierra and not Sierra as from several threads here it seems like going to HS cures the ios13 issue. Your problems may well stem from that as it sounds like you got bit by that.
Make a clone of your system and do a clean install of HS and programs. Do NOT use Migration Assassin if you can help it.
Jack
QAPLA!
Old 10-03-2019, 06:39 AM
Originally Posted by musicman691 View Post
Jeff:
Sounds like a good plan. I haven't upgraded the OS as everything was running very well. Looks like it's upgrade day!
Old 10-03-2019, 07:55 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 2018.7 sudden issues
fixed the title for you
Janne
Old 10-03-2019, 07:57 AM
Thanks, didn't know I could do that.
Jeff
PT 2018.12 + 10.13.6 issues adam_w1 Pro Tools 2018 8 01-16-2019 01:39 PM
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues Dudiester Pro Tools 2018 5 08-12-2018 08:33 AM
2018.4 crashing on launch all of the sudden Dax Productions Pro Tools 2018 3 06-13-2018 08:26 AM
Sudden issues in pro tools Mrmisterxx Tips & Tricks 1 09-25-2010 02:03 PM
Sudden BSOD issues in PT8 psi777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-02-2009 01:43 PM
