Client wants to connect to unknown proxy
When I use the client software at my studio, [bleep]it works fine. [bleep] When I try it at home, [bleep]it always want's to connect to a strange proxy server. [bleep] It asks for a user / pswd [bleep]and I can never get connected. [bleep] Port 8000? Would you have any idea why? [bleep] Something to do with DNS? [bleep] I have deleted and re-installed numerous times. [bleep] I am using 2.1.1b394. At the studio, I am behind a router. At home I am also behind a router. The same problem at home existed when I had an older router. Now I am running DDWRT V24SP1.
Can anyone help me? |
Re: Client wants to connect to unknown proxy
Chris Markle here from Aspera... There is a way to tell the client not to mess with proxies that sometimes helps in situations like this. What you can try is to add an empty folder named "noproxy" to c:\Program Files\Aspera\DigiDelivery (so you'd send up with folder: c:\Program Files\Aspera\DigiDelivery\noproxy). See if that helps...
Chris |
xxx, Debug, DD_Prefs.cpp DD_Prefs::UpdateProxySettings 678 Using HTTP Proxy: http://10.0.0.1:8080 xxx, User, DD_AppUtils.cpp DD_ParseCommandLine 377 -- blank line -- xxx, Debug, DgD_TxnHandler.cpp DgD_TxnHandler::OnPreDispatch 67 /servercomm2 executing Msg_FireCheckForUpdates [...] And the client didn;t work becasue 10.0.0.1 was not a proxy. Then I added the noproxy empty directory as I described in the earlier post and then the trace showed this 04/02/2009, 10:36:32.031, User, DD_AppUtils.cpp DD_ParseCommandLine 377 -- blank line -- 04/02/2009, 10:36:32.031, Debug, DgD_TxnHandler.cpp DgD_TxnHandler::OnPreDispatch 67 /servercomm2 executing Msg_FireCheckForUpdates [...] And the client worked even though IE was configured to use a proxy. To turn on client logging, you can either: 1) reinstall the client or "change" it via Control Panel - Add/Remove Programs and check the installer checkbox to enable logging; or 2) Add the folder called "Logs" (note uppercase "L") to C:\Program Files\DigiDelivery resulting in the folder C:\Program Files\DigiDelivery\Logs. If you do this then each time you start the DD cleint a log file called lognnn.txt will be created there. Chris |
Proxy-server restictions | Frank Kruse | Aspera DigiDelivery | 2 | 02-11-2010 06:30 AM |
DD client with ISA proxy | babel | Aspera DigiDelivery | 1 | 04-05-2008 11:25 PM |
Paging Dr. Hallada, or a proxy: A8N-E Question | ejwells | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 02-06-2006 11:14 AM |
Assertion (false) failed "proxy c " line 221 | Bender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-14-2005 09:20 AM |
-34 Media Proxy Time out error message | DigiTechSupt | Post - Surround - Video | 0 | 09-23-1998 01:40 PM |
