  #41
Old 05-24-2016, 05:19 AM
JFreak JFreak is online now
Default Recording levels? -18dbs
Not to me either. I was referring to psychoacoustic effect of louder is better. Newbies turn the mic gain, seasoned professionals the monitoring volume knob.
Would rather not even mention a 83dB calibrated listening environment but hey
https://www.soundonsound.com/sos/may...monitoring.htm
  #42
Old 05-24-2016, 10:27 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Recording levels? -18dbs
Originally Posted by Extreme Mixing View Post
A pad sounds better recorded hot? Not to me. And why record something hot only to turn it down 30 db during the mix. What a waste.
Steve
Agreed.A signal recorded loud or soft will sound the same. The only difference will be the S/N ratio. With modern recording of 24 bits with a S/N of 144 db, you'll never hear the noise.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
  #43
Old 05-24-2016, 10:34 AM
Originally Posted by Chief Technician View Post
That is only true if you apply +30dB of gain to the monitoring path to offset the -30dB of gain. Even then, I am skeptical that the audio will sound the same, since everything you could not hear before was just boosted by +30dB of gain.
My point was that a sound recorded at different levels will be reproduced without error if recorded under the Nyquist frequency limit. The only difference will be the Signal-to-noise ratio.
See this excellent tutorial about bit depth:
https://www.youtube.com/watch?v=cIQ9IXSUzuM
Park
  #44
Old 05-24-2016, 10:42 AM
I think you all will find this interesting:
http://www.orban.com/meter/
Orban Loudness Meter for Win/Mac
V2.8.2 is a major upgrade that adds support for up to 7.1-channel surround and the ability to analyze audio and the audio parts of video files offline for their BS.1770-3 Integrated Loudness, EBU R 128 LRA, highest reconstructed peak level, and number of reconstructed peaks above 0 dBFS. It will graph the BS.1770-3 Integrated Loudness and peak swings of the CBS Loudness Meter as a function of time, and can display a histogram of the BS.1770-3 Integrated Loudness.
Park
  #45
Old 05-24-2016, 03:11 PM
PatriotsBiker PatriotsBiker is offline
Originally Posted by Barry Johns View Post
This thread is a good read and should be a sticky for young up and comers!
And us old up and comers.
  #46
Old 05-24-2016, 05:49 PM
Barry Johns Barry Johns is offline
Never too late to learn! Up and comers relate to longevity recording, you can be 70 and be an up and comer! Never too late for anything!
You just bring more wisdom to the process!!!!
I'm 52 but I've been passionate about recording for all of my adult life! You'd think I'd have it mastered by now, but I'm still learning things every day!!!
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
  #47
Old 05-25-2016, 04:47 AM
Steve
^^^^ This
I'm surprised no one's mentioned the straight-line rule, i.e. recording your tracks at roughly the level they'll end up in the mix, to result in a set of mix faders that are all similar in levels. This seems an even more applicable concept today than it did back in the days of tape.
There's a "dummies" page here about it for anyone unfamiliar with the concept.
http://www.dummies.com/how-to/conten...line-rule.html
  #48
Old 05-25-2016, 04:56 AM
Wireline Wireline is offline
Getting inputs to kinda match outputs is also a great way to keep an eye (ear?) on noise... Remember that every time one boosts gain after the fact one is also boosting noise, rumble, hiss, etc. normalizing usually isn't your friend.
There's a lot to be said for providing sufficient level (NOT volume) when tracking.
Keep it down but makes sure there's enough, and it's clean on the way in. Not an issue that I know of with virtual instruments but introduce one mic, with a pre, cabling, etc, and....?
Ken Morgan
Midland, TX
It Doesn't Matter What I Did Then - What I Do Now Is What's Important
2017 Intel Mac Mini, 32G, PT 2023.12 Studio, Presonus Quantum 2626 and a bunch of stuff via ADAT
  #49
Old 05-25-2016, 07:40 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
You can do a quick test for noise. Just record something peaking at -30 and turn it up. The results shocked me. With 24 bit converters and Pro Tools LE, noise turned out to not be a problem worth even thinking about.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #50
Old 05-25-2016, 11:27 AM
Extreme Mixing Extreme Mixing is offline
Yes, this is very true. The ratio of signal to noise doesn't change at all. We all need to have clean preamps and quiet amps. But recording hot doesn't change the ratio at all. And it's too hard to make a 2 db change when when your fader is at -30.
Steve
Steve Shepherd
Extreme Mixing
Best Recording Levels spaceman Tips & Tricks 102 11-26-2011 06:53 PM
Low recording levels Krish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-29-2011 05:11 PM
Recording Levels jawjam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-20-2004 01:32 AM
recording levels Graeme Oxby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-25-2003 12:06 AM
Recording levels nickair Pro Tools TDM Systems (Mac) 2 06-23-2000 10:11 AM
