Surround Setup Help
Hopefully someone can help me, since this is driving me nuts.
I am running HD3 Accel with a 192 I/O and 1622 on the legacy port and a Control 24. I just set up surround monitors on channels 1-6 out of the 192. I am trying to put my stereo monitors on 7-8. No matter what I do I cannot get any sound out of the stereo pair on 7-8. I can pan sound to all the surround monitors fine. I/O setup has the correct channels selected for the stereo pair. I see the meters on the 192 light up on 7-8, but hear no sound. If I move the stereo monitors to 5-6, then I can hear them (so no speaker problem). Ideally what I wanted was to be able to run my stereo mixes on the stereo monitors on 7-8 and use the surround monitors for surround mixes. Any ideas at all? Thanks for any help or advice. |
Re: Surround Setup Help
On the control 24 there are 6 stereo inputs used for monitoring. The are 2 separate Dsubs for this and they are "Pro tools sources" and "External sources" You will need to hook up your output from the interface to one of the first 3 (1-6) pairs of these dsubs, which the are 2 of. 7 and 8 on the dsubs are not used.
Hope this helps
Paul |
Thanks. It did help. I had forgotten that the outs to the monitors came from the Control 24, so 7-8 on the 192 don't correspond to 7-8 on the snake out of the C24. After reading your reply I ended up setting up the stereo monitors as my alt control room monitors. I think this will do what I want, letting me work in stereo sessions as well as surround sessions.
Paul |
PT9 Le with 002 and surround setup | RuffinMedia | Post - Surround - Video | 1 | 03-25-2011 03:56 AM |
surround setup | Peter Groom | Post - Surround - Video | 0 | 05-15-2007 11:29 AM |
Surround I/O setup | pminfo | Post - Surround - Video | 7 | 12-19-2004 07:15 AM |
PT & d8b surround setup help | Doofus | Post - Surround - Video | 3 | 02-06-2004 01:14 PM |
Help with Surround Sound Setup | Shabby7 | Pro Tools TDM Systems (Mac) | 0 | 02-04-2004 02:37 PM |
