Pro-tools LE DAE plugin-error??? pls help
ive just got my m-box and have installed pro-tools...
heres the problem: every time i start up pro-tools a box with this error message apperars: could not create the plug-ins TCE factory default file because of a DAE error was encountered(#0) pro-tools starts and i can record tracks... but when i want to start a plugin in the mixer area this error message apperars: The plug-in could not be made active because of an DAE error encountered(#7400) if someone could help me getting rid of this problem i would be very greatfull my computer is a laptop: celeron 2.6ghz with about 1000mb og RAM if that is some help solving the problem |
Re: Pro-tools LE DAE plugin-error??? pls help
If you're using 6.4, you need to upgrade many Digi plug-ins which you'll find on the Downloads page.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
im using pro tools 6.1.1 and i have only installed plugins that came with the m-box
Make sure the pliugin was loaded in the proper directory. It should be in Program Files-Common Files-Digidesign-DAE-Plugins. If its not there, search your hard drive. If PT was installed on C:, it should have installed properly. You may need to reinstall PT.
Its also worth a shot to update the Pace antipiracy drivers at www.paceap.com
my program is installed in danish named directories...but the plug-ins should be the same as the common files directroy.....
what is this Pace antipiracy driver? |
Thats the problem. Protools is looking for the english directory. Try creating the directory I described above in English and drag the plug-ins to that folder. I suspect PT will then find the files and your plug-ins should work. RTAS Plug-ins are named xxx.dpm and xxx.dpm.rsr
i tryed what you said...and made the new directories...copied the plugins over...but the error is still there :-(
You probably need to delete your preferences file in the main Digidesign directory. This has info thats plug-in related but by deleting it, a new one gets created with, hopefully, the location rectified.
i tryed to delete the directory with the danish name containing the files...
but pro-tools cant find the plug-ins.... because it could find the plug-ins in the directory...but the error still accur i dont think this is the problem :-( or maybe im doing it wrong... hasent anyone had this problem??? or is there a way where i can get the answer from some kind of digidesign support?...mabye an update could do the job? but i dont know how... |
hasent anyone got an answer to this problem???
or know where i can find someone who might do? maybe a mail for some kind og digitech support??? isent there anyone who have had this problem? |
DAE error -7401 with plugin | Joe M | Windows | 11 | 02-20-2013 03:01 PM |
Hypercontrol: Convert plugin build-in presets to pro tools plugin presets | headsup | macOS | 4 | 12-17-2011 01:28 PM |
Plugin Error | curls9x | VENUE Live Sound Systems | 3 | 11-23-2008 05:17 PM |
PlugIn Error/Bug? | DennyLin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-02-2007 12:30 PM |
Tokyo plugin Dae Error | Tom_Weber | Pro Tools TDM Systems (Mac) | 0 | 04-07-2001 07:31 AM |
