Old 02-11-2019, 09:12 AM
bfgt2 bfgt2 is offline
Default Drum sample to track/midi tools
Hi folks,
Just wondering with tools such as Massey DRT and Co, can you split a single audio (stereo) drum sample to its different kit components on a midi keyboard?
I've recently seen someone do something similar. I know the split is not going to be perfect, but he the guy was then able to play individual drum parts of the audio sample kit on a keyboard.
Would something like Massey DRT work for that? I've only seen it applied to already separated audio tracks.
If not, are there any other suggestions of tools that could do that?
Cheers!
Old 02-11-2019, 10:29 AM
amagras amagras is offline
Default Re: Drum sample to track/midi tools
You can separate the hits manually, export and load them in a sample player like Structure Free included in PT.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 02-11-2019, 01:52 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Andrei is right. I'll just add a bit more to that.
Create an audio clip for each sample you want to include in a kit
Name the clips with something like "Kick C1", "Snare D2", etc where the note designation is what MIDI note will trigger the sample.
Export the samples (WAV files, 24bit 44.1k or 48k would be best)
Then, open Structure, and use the browser inside Structure to navigate to the folder where the clip samples are saved.
Then you can drag the samples in bulk over to an empty module in Structure. Each sample will automatically be assigned to the MIDI note designated in the clip name.
Now you can do whatever edits you wish and play the samples as a kit off Structure using those MIDI notes.
Good luck.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 02-12-2019, 08:52 AM
albee1952 albee1952 is online now
What they said^^^ Indeed, I have created new drum tracks from a single stereo drum mix with a lot of chop/copy/paste to new tracks and trigger with drum replacement plugins(done it with Drumagog and Slate Trigger).
As for something else, you might be shocked at how well Superior Drummer 3 will do this. Import the same mixed drum track multiple times and assign each to your sound of choice(IOW, set one for Kick, another for Snare, another for hihat, etc) and let the plugin analyze. I was stunned at how well it did
MIDI notes disappearing when switching MIDI track from sample- to tick-based XJENSEN Pro Tools 12 7 01-11-2017 12:12 PM
How do I add drum sound to a midi track? RunningFree Pro Tools SE and Essential (Win) 2 05-10-2011 11:41 PM
MIDI Drum Track Not Playing bmcoonan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-18-2009 03:23 PM
MIDI Drum Sample Player for OSX LE 6.0.1? Mety 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-10-2003 06:29 PM
MIDI drum track MrMike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-07-2002 06:17 AM
