Old 08-07-2018, 10:52 AM
Magnetic Magnetic is offline
Default PT Control not connecting and freezing since 18.3.xx
I'm running PT Ultimate 2018.7 with EuControl 18.3.0 on Mac OS 10.13.6. My late 2013 iMac and ProTools Dock are connected via ethernet to my Apple AirPort, and my iPad Air running iOS 11.4.1 is connected via 5GHz ethernet.
Since the latest EuCoN Unified Installer, the only way I can get PT Control to connect is by powering down and restarting my iPad. Once connected, everything is hunky dory, but if I shut down ProTools, or sleep the iPad, EuControl on the iMac becomes unresponsive and won't respond to the Restart EUCON Applications command. I have to force quit EuControl, and power down and restart my iPad to get it to work again.
This entire setup worked fine until the latest EuCon update. I've tried uninstalling EuCON and reinstalling, but all remains the same.
Anyone else having this issue?
Old 08-10-2018, 07:33 AM
legodo legodo is offline
Default Re: PT Control not connecting and freezing since 18.3.xx
Ihave the same issue with my Mac mini 10.13.6 and last protools control on my iPad air 2 !! It's time to make an update !!
Old 10-17-2018, 10:06 AM
saspro saspro is offline
Having the exact same problem
Any ideas?
MacPro OS 10.10.5
iPad iOS 11.4.1
EuControl (MP) is 18.3.0.24 3/16/18
PT Control (Ipad) is 18.3.0.208 (2/27/18)
Old 10-18-2018, 04:56 PM
ha2dorff ha2dorff is offline
Same problem here.
Until this is fixed, I always turn my iPad off before I turn my Mac Pro on.
After EuControl is loaded, I turn on my iPad.
Everything is working fine with 2018.10 this way.
11R Control Panel keeps freezing! MichaelUR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-03-2011 04:59 AM
mc control freezing norbury brook Artist Series 22 08-26-2011 01:49 AM
Mc Control not connecting at all desafio Artist Series 1 04-16-2011 10:49 AM
Waves SSL G-EQ freezing, not compatible with Control 24 crizdee Pro Tools TDM Systems (Mac) 7 05-13-2008 05:42 PM
Connecting Control 24 w/everything else I have. G59south ICON & C|24 2 05-19-2006 10:03 AM
