Old 02-23-2019, 05:35 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Default Re: Sample accurate digilink interfaces in 2019?
Originally Posted by JCBigler View Post
What does sample accurate mean?
It means that the frame roll-overs line up exactly on the correct samples with no slop.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 02-25-2019, 01:40 AM
D'Animation D'Animation is offline
Originally Posted by LDS View Post
Hey everyone,
What current digilink interfaces are sample accurate to 192s or HD I/O?
Obviously Avid stuff. I assume the Symphony and new Aurora N continue Apogee and Lynx's trend of being sample accurate? Mytek? What about Burl, the Focusrite Red stuff and Antelope Audio HD interfaces?
In the same boat - Apogee Symphony and Lynx Aurora (n or the older 8/16 models) are sample accurate. The Antelope Orion/Goliath appears to be too (though I haven't read any user accounts to confirm that). The focusrite Red (4pre/8pre/16L) is NOT sample accurate - damn shame as its the perfect amount of connectivity for me. And the compensation window is in msec, not samples so you'll never manage to accurately compensate it the way things currently are
Old 02-25-2019, 04:15 PM
It is not likely to matter unless you are mixing IO hardware
Old 02-25-2019, 06:07 PM
BScout BScout is offline
It would matter with parallel compression using a hardware compressor, for instance
Old 02-25-2019, 06:14 PM
JFreak's Avatar
JFreak JFreak is offline
Yes, but only when you're using two different brand interfaces there (only use one interface and stay in sync)
Janne
  #16
Old 02-25-2019, 07:55 PM
Try this again:
Focsurite red presents itself to the HDX card as a HD I/O with a 17 sample RTL.
It actually has a RTL of 14 samples
ProTools will compensate a hardware compressor for 17 samples attached to the Focsurite red.
Parallel compressing, the direct signal will be 3 samples behind the compressed. Mixed interfaces aren’t the issue.
  #17
Old 02-25-2019, 11:16 PM
JCBigler's Avatar
JCBigler JCBigler is offline
I mean, this is only relevant if you are sending a signal outside the box, from one interface to another, right? If everything stays inside the Protools mix engine, it doesn't really apply, right?
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
  #18
Old 02-26-2019, 01:58 AM
JFreak's Avatar
Sure it is a mixed interface issue if one is Focusrite and another is Avid -- however in this care the solution is easy, just ask Focusrite to add 3 samples of delay to their guess of HD interface latency
Janne
  #19
Old 02-26-2019, 02:17 AM
If I remember correctly from Focusrite support & other user reports their converter delay is longer than the Avid i/o
  #20
Old 02-26-2019, 06:00 AM
JFreak's Avatar
Makes sense. Then there is nothing that can be done, right? If a 3rd party interface would be faster than Avid's they could match the RTL by slowing it down
Janne
List of third-party Digilink interfaces? Matt Hepworth Pro Tools HDX & HD Native Systems (Mac) 14 11-19-2023 02:49 PM
Interfaces under Inputs say DigiLink N/A. What's going on? [solved] Focuret Pro Tools HDX & HD Native Systems (Mac) 0 03-17-2018 10:23 AM
Sample accurate recording derekvh Post - Surround - Video 2 02-03-2014 08:55 PM
AC3, is it Sample Accurate? minister Post - Surround - Video 13 03-13-2007 10:57 AM
Sample accurate midi? Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-09-2005 11:48 PM
