Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 09-13-2012, 07:08 AM
The golfer The golfer is offline
Default European vs North American MC Pro
I am wondering if someone can shed a light on this.
I am living in Canada. Can I use a North American MC Pro power supply with a European MC Pro?
Does the power supply from the latest MC Pro (black colour) work with the earliest (silver) Mc Pro?
Thank you.
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Old 09-13-2012, 08:06 AM
klaukholm klaukholm is offline
Default Re: European vs North American MC Pro
In some cases it will not work without trimming the 5v voltage and possibly rewiring the pinout (changing commons)
I would suggest buying a new PSU from digital audio service in germany
Old 09-13-2012, 04:56 PM
But if i want a north american power supply. Wouldn't be better to buy it here in canada? And would a european Mc pro work with this new power supply here in canada?
Thanks!
Serge Hamel
Old 09-18-2012, 12:13 PM
There's a reason companies use external power supplies - so when you change countries you just change the power supply; you don't have to mess around inside the equipment being powered. Doesn't matter for which market the MC Pro was made for; there actually shouldn't be any difference between units (they should all be the same). Color of the unit doesn't make a difference to the power supply.
But back to the original question: buy the appropriate power supply for what is useable in Canada. And that would be the same one used for the US (actually all of North America which consists of the continental US & Canada uses the same voltage - 120VAC at 60 HZ for most domestic use; 240VAC for appliances like electric dryers and stoves).
Edit for additional: looking at the specs for the MC Pro it looks like it has what's called an auto-ranging power supply. That is - it changes on it's own (or is changeable by the end user) for a range of voltages encompassing what's used in North America and Europe. All you may have to change is the power cord for the power supply. If it's what's called a switching power supply then those are, by design, able to work on a very wide range of AC mains voltages by design.
Jack
QAPLA!
Old 09-19-2012, 09:50 AM
That 's great. Thank you very much for the details infos.
Serge Hamel
Old 09-21-2012, 03:25 PM
Thanks!
The psu from germany is a custom job, 110v is no problem.
The original PSU is switching and is capable of both 240v and 110v
Old 09-21-2012, 03:35 PM
Thanks klaukholm.
Serge Hamel
Old 09-22-2012, 05:23 AM
ErikGuldager ErikGuldager is offline
Default
The original units are crap, at a minimum needs modifying with new fans as the original are loud!
We have a S5MC and a stand alone MC, I think at least five or six units have failed during five years.
Old 09-23-2012, 05:07 PM
Strange...We have 2 x 24 inputs 2008 System 5 MC and we never had any problem with them apart from the noisy power supply. May be the older generations are cheaper.
Serge Hamel
Old 09-23-2012, 05:40 PM
If you open it up, it is a real hackjob and it is no surprise that they blow.
Greetings from North-East UK :) geiger167 General Discussion 1 02-18-2009 07:24 PM
The Great White North... lemix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-04-2004 04:26 PM
do i have to buy "european" version of digi002, or use "american" with power adaptor? stoka General Discussion 3 10-04-2002 06:28 AM
am i the only pro tools fan in North Dakota coaster General Discussion 13 11-15-2000 09:39 PM
american/european models mwen1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-03-2000 11:19 PM
