Dock chooses wrong channel
I am getting some new behavior where if I select a track for volume automation via the Dock fader, the Dock will select and write automation to either the track above or below the track selected. If I reselect the track it will then write to the correct track as long as I do not let go of the fader. If I write volume automation, then let go of the fader with the transport still running, the next time I touch the fader it will switch to the track below the selected track and write automation to that track instead. Any insight would be helpful.
Mac OS 10.11.6 PT 2018.12.0 Eucontrol 19.12.1.23 |
Re: Dock chooses wrong channel
It sounds like the track isnt getting attentioned. Whats the Blue boarder around the tracks doing ?
Hey Eddie. Thanks for the response. Blue border has an orange top, but will surround whichever track the Dock focuses on.
So to be clear the fader on the dock is not writing to the track with the blue boarder (on the bottom)
No, it is writing to the channel with the blue border at the bottom.
The issue is: a. I will have selected a track and Control will attention the track either above or below the track I have selected and write automation to that track, or: b. Control will attention the track I select and write automation to it, then if I let go of the fader for a second without stopping transport, Control will move attention the track below the track I have selected and write automation to that track instead the next time I touch the fader. Make sense? |
You make sence but the issue doesnt ;-) Do you have attention on touch enabled in EuControl...maybe post an image of your settings here.
Looked, and noticed "Auto bank to clicked track" was not selected, so I selected it too. Doesn't explain why it would select a different track without me touching anything though.
Dock Channel strip LED don't work | Artis | Avid S1, S3, Dock and Control App | 18 | 02-14-2020 01:06 AM |
5.1 channel order wrong. | LDS | Post - Surround - Video | 1 | 10-30-2019 07:45 AM |
Missing Q Parameter on Channel Strip Through Dock? | barden | Avid S1, S3, Dock and Control App | 3 | 09-26-2016 12:06 AM |
CAF channel-order still wrong in 9.0.5 | Arno Peeters | Post - Surround - Video | 3 | 07-26-2015 07:55 AM |
CIA chooses Behringer FX units!!!!!!! | tptman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-16-2002 03:42 AM |
