4 head phone mixes out of a digi rack 02
Is it possible ? I have an Art 406 ,6 channel head phone amp .
Thanks Jim
focusrite liquid saffire 56 ,digi rack 02/ presonus digimax 8, allen heath gl2432, mobo asus m4a88td-v evo/usb3, AMD 1075 sixcore corsair XMS3 ddr3 4g (x4) western digital 1tb hard drive 7200rpm(x 2), 680watt power supply no name, windows7 home premium 64 bit |
Re: 4 head phone mixes out of a digi rack 02
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Thanks,
Are you referring to 4 discreet (separate) mixes... or one mix sent 4 places?
I believe either are possible with the 002, but the ART only has one stereo input i think, so you could split the same mix 4 ways.. ff |
To clarify what has been said here. The 002 is capable of 4 mixes, IF you use the SPDIF out as your control room. That particular headphone amp looks like it CANNOT do 4 separate mixes. It could feed 1 mix to 4 sets of phones, and MAYBE 2 mixes so each player could choose A or B. A better solution could be done with the Behringer HA4700 headphone amp. That one has 4 sections that each can receive a main stereo feed, and each section has an AUX input, which could be a stereo(or mono) mix to each of the 4 sections. What I do is a hybrid. I feed the main stereo mix to the main inputs of the 4700 so all 4 players get that. Then I send a mono "more me" feed to each section using up to 4 mono aux sends, fed to analog outputs 5 thru 8. While this is not how the whole system SHOULD work, by building special cables for the 4 sends, it works great(balanced mono on one end, to UNbalanced stereo summed at the other end. Here is how to wire that cable if you ever need it: http://i182.photobucket.com/albums/x...wiringcopy.jpg
I do the same as albee1952. I use the bus's to control hom much of each track is going to the headphones. I use the analog outs on the Digi002 to go to a Behringer 4 channel headphone amp (cheap on Ebay). The Behringer has a mix knob that allows me to mix in a live signal, such as the direct monitoring out on a Great River preamp with the signal from ProTools. You can use the 8 analog outs on a 002 and send whatever you want to it in the I/O area of PT. I monitor from the S/PDIF outs into an Apogee Rosetta so my analog outs are freed up for headphone mixes.
Huh? The Art 406 has a insert for each channel. It would be a mono mix for each channel. He just needs four analog outputs from his 002 and four TRS leads.
Mono cue mixes... long gone. But If the OP needs 4 discreet mixes that is about the only way to do it (with that hardware). YUK!! so 70's!
Head Phone Mix | DonaldM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-08-2010 11:01 AM |
Using a head phone amp with control 24 | bellpro | ICON & C|24 | 7 | 03-01-2007 01:51 PM |
Head phone mixes | mastermorris | Tips & Tricks | 1 | 02-05-2007 07:24 PM |
Head phone amp... | ghost22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-15-2006 07:47 PM |
Head phone mix? | sheeptuf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-27-2004 07:01 PM |
