Re: Invalid fades on playlist "?"
I still find it odd that it would find it at the location I described in my previous post. This is just a 20 minute reel! But as long as this doesn't harm the session as I've been told (I still haven't investigated fully) then I'm gonna keep ignoring the message. -Justin
Justin Walker |
I've just had that message
'invalid fades detected ' at some ridiculously high seesion time where no fades existed.. (trashed dbs etc, trashed and re-created fades, etc... peoblwm still around, with session) Since i had a very large session (5 reels in one, 192 channels) i split it up into reels, 'invalid fades' message was gone afterwards. my2cents v. |
Just closed my session and re-opened. PT10HD comes up with a
"The following invalid fades were detected: Fade out at 347222:59.463 on Playlist "?"" What does this mean? What is playlist "?". My session doesn´t contain a playlist with that name. Saved the detailed note text file. It says: "These fades can not be re-created if they go offline" Problem is: What is an offline fade according to PT10?! Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Another strange thing is that you can´t even enter a bar with 6 digits. Bar 43201 is maximum in my session.
How am I supposed to find and get rid of the corrupt fade? Actually haven´t seen these corrupt fade errors since PT6. Also: I din´t actually do anything. The error just occurred between one close and one open of the same session. Nothing changed in between. I can send out an offline session in case DTS is interested. Frank.
DTS,
I can not get rid of this error-message. Can I send you the session file? What does "Playlist "?" " mean? Where is playlist "?". Also how can I go to bar number 347222:59.463 to find and eliminate that illegal fade? Thanks! Frank.
#16
In the meanwhile my session has "gathered" hundreds of these invalid fades on playlist "?".
Every time PT asks me if I want to save a detailed note and I hit "yes" nothing happens and I'm left with a stuck progress bar and a cancel button. When I click it I only get a ping from the OS. The only way out is to force-quit PT. Is there a way to get rid of these fades? They seem to live in a location I don't have access to (see earlier posting). I'd love to post the details report but PT won't let me save it. Cheers, Frank.
#17
I'm also getting this error. It started after I cleared a bunch of unused clips from my session. HELP PLEASE AVID!
#18
I still get this in PT11. Opened my work-session this morning and a bunch of fades where flagged on playlist "?".
Nothing had changed over night. Simply saved yesterday, opened today. No invalid fades when I left off. Today there's a whole list of them Frank.
#19
Happened again in 11.1.3. Opened a session in the morning and got the same errors out of the blue that won't go away anymore.
Frank.
#20
I'm also having this "?" error message with one of my current session. It came after I reverted session using backup file. Otherwise session is fine but it would be nice to remove those corrupted parts of it.
I would also like to know how to remove those "?" files/fades. There is no '?' named playlist in my session. (Exporting session didn't help). Message (when loading session): -------------------------------------------------------------------------------- Invalid fades (these fades cannot be regenerated if they go offline) Fade out "" at 347222:38.906 on playlist "?" is invalid because its left contributor is a fade. Crossfade "" at 347222:47.767 on playlist "?" is invalid because its left contributor is a fade. Fade out "" at 347222:52.650 on playlist "?" is invalid because its left contributor is a fade. Fade out "" at 347222:15.066 on playlist "?" is invalid because its left contributor is a fade. |
Has "Some regions had invalid bounds and were adjusted or deleted" been fixed? | meech | Pro Tools TDM Systems (Mac) | 22 | 06-21-2014 12:47 AM |
"Some regions had invalid bounds and were adjusted or deleted" | WildHoney | Pro Tools TDM Systems (Mac) | 243 | 08-13-2013 08:42 PM |
New Mbox Pro "Invalid Authorization Code" | envO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-11-2011 09:57 AM |
"Some regions invalid bounds and were adjusted or deleted" A duplicate Audio Folder ! | acmost | Pro Tools 9 | 0 | 11-13-2010 05:40 AM |
