Pro Tools Open send plugin macro/shortcut
Hi
Is there a shortcut or macro for raven to open the plugin parameters for a send without scrolling all the way to the bus channel where effect is inserted? In other words I have track 1 as vocal and I have a reverb send. If I want to adjust parameters I have to scroll to end of mixer view to where the effect bus channel is and click on its insert make adjustments etc. can I create a macro so if I want to adjust plugin parameters for send I can click on that channels send and opens window? I can do this in cubase with shortcut option/alt + double click On send and plugin opens. thanks Todd |
Re: Pro Tools Open send plugin macro/shortcut
Move the buss up next to the track where the send is from?
Or :
open the reverb plugin, place it at a good position on the monitor, save it as a new window configuration. Maybe name it "Reverb". Recall that when needed. Or : hide every track except vocal track and reverb track, create a memory location (attributes : None , Track show/hide , Track Heights), maybe name it "View Voc + Rvrb". Recall when needed. Include in the attributes of that mem loc the above window configuration "Reverb". Comma, (the number of the mem loc), Comma to recall. (NumPad).
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Great point, especially since mix/edit window follows banking doesn't work with the eucon controllers like S3 in VCA spill mode.
Dragging your send track next to the audio track is kinda pointless if you have dozens of tracks routed to the same sends. Best thing I found so far is page-up/down to get the tracks in view quicker in the edit window. As an improvement on that I got a mouse with extra thumb buttons and assigned page-up/down to 2 of them. It sounds absolutely ridiculous, but it's amazing how much it fastened my daily workflow. |
Yes, and Alt + Page up/down in the Mix Window.
Macro for inserting a certain plugin... | GW | Artist Series | 3 | 02-03-2011 10:32 AM |
Is there a shortcut for send groups? | M2E | Pro Tools TDM Systems (Mac) | 4 | 11-09-2007 04:25 AM |
Shortcut for raising send fader? | Naagzh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-10-2007 10:01 AM |
Shortcut for Aux Send | studio rec | Tips & Tricks | 1 | 10-01-2005 06:22 PM |
Keyboard Shortcut for Aux Send | Eless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-20-2005 05:50 PM |
