Old 10-19-2010, 09:02 AM
pezking pezking is offline
Default Re: HD Native on Core Cards
So you think the HD Native card is vastly different to a TDM card in its design? So different that if Avid wanted to, they could not implement a software mixer using TDM cards? I find that hard to believe, and in fact would go so far as to say it's rubbish...
You can use your 192 + HD Core card as an interface for third party DAWs, so there is no reason whatsoever that, if Avid wanted to, they could run Pro Tools Native using the TDM card as the interface.
Old 10-19-2010, 09:09 AM
Dism Dism is offline
But why would you want to...?
TDM does more than Native.
It doesn't look like it now... because the current line of TDM cards are vastly underpowered compared to current native processing, but when the new TDM cards come out, it will all make sense.
There will be no reason to run Native on a TDM card.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 10-19-2010, 09:23 AM
Like I said, I know the relative merits of TDM and Native.
I don't want to do it! But it would be better for users of say HD1, who feel that now Native would be more powerful; if they could run Native on their existing hardware.
Like I said, you've missed the point of my post all along! :)
Old 10-19-2010, 09:25 AM
I really haven't missed the point... I understand your point. All I'm saying is that it's never going to happen.
Avid created HD|N to be an entirely separate solution from TDM. HD1 looks underpowered now only because of timing. Come another month or two... the tables will turn.
D
Old 10-19-2010, 09:59 AM
studiojimi's Avatar
studiojimi studiojimi is offline
the day that happens
i will remove "hold fast baby hold fast" from my sig line.
(at least for a day LOL)
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
  #16
Old 10-19-2010, 12:26 PM
DigiTechSupt's Avatar
Let's clear up a few things about all of this.
The Pro Tools version that runs with Native is *exactly* the same as the HD version in functionality. The only difference being Native cannot run TDM plug-ins and HD is a tad bit faster as far as monitoring latencies go - and you can run TDM plug-ins with near-zero latency.
HD systems are extremely unlikely to ever run the mixer on the CPU. The round trip latencies for doing so would completely dissolve any of the benefits of the near-zero latency monitoring capabilities of HD.
Avid Audio Tech Support
Support FAQ
  #17
Old 10-19-2010, 12:48 PM
Firechild Firechild is offline
Native means processing on the native CPU so, it would be easy to make the HD core card as a native input I/O card. We have already that feature with the core driver but it is limited to 8 I/O.
If you say that your PT HD Native card is handling the mix engine too, you are using the word "Native" in completely the wrong way.Totally wrong.
I wouldn´t be surprised if the new HD Core TDM card looks pretty similar to the native card. I guess the native card is a crippled HD Core card based on the HUGE heat sink.
Can someone remove the heatsink and check which SHARC CPU there is?
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
  #18
Old 10-19-2010, 02:27 PM
No, it's NOT easy. There are huge differences between getting 8 channels from a Core Audio driver and having a full-fledged, low latency system that can use TDM plug-ins.
I didn't say that. I said the CPU ran the mixer.
The Native card bears almost zero resemblance to an HD Core card - it's a completely different design.
Support FAQ
  #19
Old 10-19-2010, 04:02 PM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
It's not a SHARC. It's an FPGA.
http://en.wikipedia.org/wiki/Field-p...ble_gate_array
Which Mac Pro for HD Native? 2008 8 Core or 2009 Quad Core? sws2h Pro Tools 10 6 11-03-2011 03:23 PM
What is the thermal output/heat load of HD core cards and process cards? yosemitesam Pro Tools TDM Systems (Mac) 0 10-24-2011 02:39 PM
prottols core cards mix core to hd pci to hd pcix to hd pce Filmusic Windows 1 03-24-2011 04:24 PM
Mac Pro Dual Quad core compatable with HD pci core & accell cards? PT8716 Pro Tools TDM Systems (Mac) 3 06-28-2010 07:35 AM
HELP!!! running 2 core cards on mix sys & lights on cards??? HELP!!! A Spooner Tips & Tricks 6 07-08-2009 06:55 PM
