There is a shortcut to select the next or previous track?
There is a shortcut to select the next or previous track? Not the cursor, but the track itself.
Re: There is a shortcut to select the next or previous track?
In the edit window: P & :;
I don't think there's any for the mixer.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Not this one. Like I said, not the cursor, not the selection. But the track itself.
Are you talking about the material in the track? If so than not that I know of.
I guess he meant to actually "select" a track so that it gets highlighted.
If this is the case then the answer would be "no". This can be scripted via AppleScript but I am not sure what the OP is after. |
That's it, thank you. So no shortcut ... perhaps with EuCon (MC TRANSPORT)
If you combine "Link track selection & edit selection" under Options, and P & ; (as mentioned above) does that do what you want? That's how I select tracks in the edit window.
Yes ! I had not thought, it's a feature I always leaves off. Big thank you.
Glad I could help!
I guess I misunderstood what was wanted, my bad.
Surround Panner 'select track' shortcut? | aasteveo | macOS | 0 | 02-19-2013 12:04 AM |
Shortcut to Select Next/Previous Track | headsup | macOS | 8 | 02-21-2012 01:23 PM |
Keyboard shortcut for selecting next / previous track in Mix window? | spinsah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-28-2009 12:37 PM |
"select next/previous track" "rec enable track" key command? | maufau | Pro Tools TDM Systems (Mac) | 6 | 04-22-2008 05:08 PM |
Previous/Next Shortcut for Expand??? | John Pisciotta | Virtual Instruments | 0 | 06-13-2006 08:37 AM |
