Old 01-29-2013, 02:05 PM
ZiviMusic ZiviMusic is offline
Default The Current Playback Engine Does Not Support A Sample Rate of 44.1Khz
I just recently Upgraded to PT 10.3.3 as well as to OSX 10.8.2 . Now, when i go to use the 3rd Gen Mbox Mini, it says "The current playback engine does not support a sample rate of 44.1Khz" and then it won't open the session. This happens with all sessions... all of which worked with the Mbox mini before. When I use the Mbox 2 pro, it works just fine.
Anyone run into the same problem? Any solutions?
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 05:32 AM
The current playback engine does not support a sample rate of 48 kHz. allegrarc macOS 9 11-27-2014 09:43 PM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 09:26 AM
The Current Playback Engine Does Not Support a Sample Rate of 48Khz justus1900 Pro Tools 9 14 10-23-2012 01:45 PM
The current playback engine does not support a sample rate of 44.1 khz murdafew Pro Tools M-Powered (Win) 4 05-14-2010 03:21 AM
