Old 04-23-2022, 02:23 PM
jsbach jsbach is offline
Default iPad as second monitor for video when composing?
I'm thinking of getting an iPad to use as a second monitor for the Pro Tools video window when composing while traveling. Has any tried this with Sidecar? Is it as easy as just dragging the Pro Tools video window to the iPad?
Just want to make sure it will actually work before I go and purchase an iPad.
Thanks!
Old 04-23-2022, 03:39 PM
Eric Lambert's Avatar
Eric Lambert Eric Lambert is online now
Default Re: iPad as second monitor for video when composing?
I tried it when the option of using an iPad as a 2nd monitor first appeared in the OS, and it worked, though video wasn't perfectly smooth.
If I get some time this weekend I'll give it another shot and post the results. FWIW I'm on the latest versions of PT and MacOS and iOS.
Old 04-23-2022, 10:55 PM
moogboy100 moogboy100 is offline
Save the money and get one of those compact USB-C bus powered displays like the Asus Zenscreen.
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.3 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.3
Old 04-24-2022, 09:04 AM
its2loud its2loud is offline
I second this. I recently purchased a 15.7” portable monitor that works great as a second screen. I found that using sidecar works well for a static screen, a connected screen works better for viewing video in Pro Tools and is 1/4 of the price of an iPad.
Old 04-24-2022, 10:31 AM
audiobob's Avatar
audiobob audiobob is offline
Originally Posted by jsbach View Post
Thanks!
It works perfectly for me. I do have an iPad Pro and plug it in via USB-C and use Sidecar. I've found using WIFI is a little less stable...even right next to the computer. When you launch Sidecar, the iPad just shows as a second monitor and yes, just drag video over. Works really well.
Old 04-24-2022, 10:47 AM
Thank you for confirming! That's what I was hoping for. The iPad seems like a great solution for travel because I like keeping the video on a separate screen.
Old 04-24-2022, 10:50 AM
Thanks for the reply! I was looking into some iPad-like options from other companies. I don't mind going non-Apple. I just figured that the iPad would be more reliable. I'm mainly looking for an option that is light and compact for travel use.
Old 04-24-2022, 10:54 AM
audiobob's Avatar
I also bought this magnetic iPad stand. Works well for me.
https://www.lululook.com/products/magnetic-ipad-stand
Old 04-26-2022, 11:44 PM
heykenny heykenny is offline
I recently ran a three screen mobile setup using an iPad Pro via Sidecar as well as a portable 17" USB C monitor with my M1 13" MacBook Pro and it worked really well. I had the PT Edit window on the 17", video on the MBP and plugs, script, meters etc on the iPad. When I was testing the system out though I had both the meters and video windows running on the iPad and was pleasantly surprised by how good the sync and response was. I think an ipad would probably work quite well although a portable monitor is a cheaper solution.
Outputting Video To External Video Monitor chadjhughes Pro Tools 2019 3 01-05-2020 02:58 PM
iPad app for playing roughly synced video? LukeHoward Post - Surround - Video 9 12-16-2017 06:46 AM
Importing iPad video to MP 8.0.5 RichrdC Pro Tools M-Powered (Win) 0 06-11-2013 08:44 AM
Control the Eleven Rack from an iPad/Android Tablet - Video Benoni Eleven Rack 8 10-09-2012 08:46 PM
Database... Video Monitor(s) Size & Video Card jbr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-19-2001 02:23 PM
