Old 01-23-2011, 06:12 PM
0just_ice 0just_ice is offline
Default Update to 9.0.1 Failed
Hello!
This is my first post on the Avid Audio forums, and I am glad to be with fellow recording/audio enthusiasts!
Sadly my first post is a technical support question.
Wondering if I could get some assistance with it.
I recently upgraded Pro Tools LE to 9.0, and then found out that 9.0.1 was released. So I waited for a good hour for it to finish downloading and then fired up the .dmg, hoping for a smooth ride.
As it is with Pro Tools, that never happens, and sure enough it said there was not a valid Pro Tools system on my computer.
Is there a good fix for this, or is it a "reinstall Pro Tools" type of issue, like so many others?
Thanks for the time guys.
Keep on keepin' on.
Old 01-23-2011, 07:29 PM
smpkeys smpkeys is offline
Default Re: Update to 9.0.1 Failed
Mine worked flawlessly. Downloaded update, installed, then restarted and downloaded the Midi fix. Then repaired permissions 3 times in a row, restart, all working fine.
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
Old 01-24-2011, 08:40 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Need much more info.
Was PT9 working fine?
What is your OS? Mac I guess.
Computer, RAM, drives?
Did you have any previous PT versions installed beside 9?
Please read this:
http://duc.avid.com/showthread.php?t=193636
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-24-2011, 09:31 AM
Please read this:
Greetings...
Yes, PT is/was working fine.
I use it every day.
I have a MacBook Pro, 2.4 GHz, 2 Gigs of RAM, running OS 10.6.6, recording out through a Belkin Firewire 400 ExpressCard to an Avastor HDX 7200 RPM external drive.
And like I said, I updated to PT 9 from the latest version of LE.
Any ideas?
Old 01-24-2011, 09:55 AM
YoRugMan YoRugMan is offline
Do you have your Avid account up and running?
I upped from LE as well, and the FULL v9.0.1 was available for download after registering - not just the update to 9.0.1
Recommend you try it that way.
"Well, of course, their requests for subsidies was not Paraguayan in and of it is as it were the United States government would never have if the president, our president, had not and as far as I know thats the way it will always be. Is that clear?"- Chevy Chase, Spies Like Us.
Old 01-24-2011, 09:59 AM
Did you have your previous version of Protools installed in a different location (directory) than the default? Did you move the previous Protools directory to another location as part of organizing you hard drive? Are you installing PT9 into the same directory as your previous Protools version?
I'm assuming you are using the updater and not the full installer (both are available for download in the crossgrade. If it still does not work, try downloading the full installer and remove you current version of Protools from your system before installing. As always, make a good backup first.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 01-24-2011, 10:07 AM
Right.
Uninstall completely first. Install the drivers then install 9.0.1. Or you can use the new drivers and install them last.
So you are not using any external hardware.
How is your i-lok? Is it the new one? Downloaded all the correct permissions from i-lok?
Park
Old 01-24-2011, 12:15 PM
Wow thank you all for your eagerness to help, I really do appreciate it!!
And, what's more, I found the issue.
Obsidian Dragon mentioned directories so I checked them out and sure enough, the directories were messed up.
Folders weren't in their rightful place, etc.
Thank you all very much for your help!
Old 01-24-2011, 06:37 PM
Yes, Macs expect to see certain things in certain places.
Obsidian Dragon gets the gold star today!
Park
Old 01-24-2011, 10:14 PM
I'm just happy to help. Maybe Avid will reward me with the Complete Production Toolkit
Obsidian Dragon
[IMG] code is Off
Update to 10.3.2 failed, can't reinstall 10.0 rickluque12 Pro Tools 10 5 11-01-2012 10:33 AM
FWx firmware update failed! sersol VENUE Live Sound Systems 4 09-14-2012 11:49 AM
Mbox 2 failed firmware update!! Help! circuit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 05-15-2012 02:01 PM
003R Firmware Update Failed...7.3 to 7.4 Kourquie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-22-2009 01:22 PM
Pro Tools LE 6.9.2 update failed striegl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-20-2005 02:14 PM
