Old 05-23-2013, 11:37 PM
P_J P_J is offline
Default "Compressing" automation breakpoints
Is there similar command to "compress" automation data like DP's Change Continuous Data?
Example: I receive OMF from editor who has used +12dB volume automation in many places and I don't want faders to go above +0dB. In DP I can use Change Continuous Data to limit (only) high volume breakpoints, so that CCD only affects to volume automation above the chosen level (e.g. +0dB).
How to do this in Pro Tools?
Old 05-24-2013, 12:23 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: "Compressing" automation breakpoints
Attachment 253
Not exactly what you want but volume trim can be used to either pull the overall volume down so the faders don't go above +0db or it can even be used to push the volume so high it will level out when it hits the ceiling.
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-24-2013, 06:05 AM
P_J P_J is offline
Ok. Thanks. ..and bummer. This (CCD) is very usefull and fast way to adjust automation data. Avid should really copy some features from Motu :)
Old 05-24-2013, 09:38 AM
Craig F Craig F is offline
if you are on 10, convert Automation to Clip Gain
Thank you,
Craig
Old 05-24-2013, 11:24 AM
P_J P_J is offline
Thanks, that could be a workaround. Currently I have Native 10 and there's no Convert Automation to Clip Gain.
I was hoping to get CPTK PT 11 (because I already have all the hardware I need), but it seems that 11 won't have that option. So my trip to PT might not even start (for a real work). Don't know yet.. There are some advantages in PT, but it lacks many functions I daily use (also HD version). If I could get CPTK v.11 (and 12 etc), I would definitely buy it.
PT10 : Volume automation disabled after "Save copy In" brenny Pro Tools 10 2 06-18-2015 02:33 AM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
