Old 02-12-2012, 03:31 PM
World Spirit World Spirit is offline
Default Eleven Rack headphone port versus MBOX and other interface headphone ports
I'm asking for your feedback on sound quality. When you listen to the 11R's headphone port does it sound better than the exact signal being sent to your interface's headphone port?
Old 02-12-2012, 08:27 PM
Default Re: Eleven Rack headphone port versus MBOX and other interface headphone ports
I thought you got your issue with the headphone output and the SPDIF connection between your Eleven Rack and the Mbox3 or Saffire interface sorted out in the other thread here . Are you look for another solution?
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 02-12-2012, 08:35 PM
Its resolved to satisfaction, but there is still noticeable differences and it seems due to either the conversion process or the headphone port. I'm trying to get honest feedback from everyone comparing their interface headphone port to the 11r's.
Old 02-12-2012, 11:34 PM
zedhed's Avatar
zedhed zedhed is offline
If I were you, I wouldn't get too tied up in differences in headphone outputs.
These devices are designed to be used for the most part as either semi professional or professional pieces of hardware in a studio environment with reference monitors.
Headphones have their place in the studio but are certainly not used 100% of the time instead of monitors.
To get a real sense of the true capabilities of them, listen to them in the right environment ie. @ line level with monitors.
If you then start talking about the differences between them I think you will be taken far more seriously.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Eleven Rack headphone out Frankenbeats Eleven Rack 12 02-12-2013 09:17 PM
Separate headphone mix with Eleven Rack gutterfly macOS 1 11-09-2012 07:05 PM
Separate Headphone Mix for Drummer using Eleven Rack and PT9HD sharchik Pro Tools 9 11 08-21-2012 08:33 PM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
003 Rack - Alt Mon Output to Headphone Amp? lowlights Windows 4 10-17-2011 12:04 PM
