Use New iMac as 2nd Monitor on 2010 Mac Pro
I hope everyone is safe and healthy.
I have a mid-2010 mac pro (cheese grater) that I use only for pro tools/music production. I also have a new iMac that I use for pretty much everything else. When working on music, I'd love to use my iMac as a second monitor. Any suggestions on how to accomplish this? Thanks! |
Re: Use New iMac as 2nd Monitor on 2010 Mac Pro
I believe you can do this with a thunderbolt cable or mini display cable. Google "target display mode".
2010 mac pro does not have thunderbolt. need to find a way to get it in as DVI
Thanks all,
I'm going to try the mini DisplayPort to Lighting cable. |
So I grabbed this cable: https://www.amazon.com/gp/product/B08575F91W/
I turned on both computers and then pressed Command > F2 on the iMac but am not having any luck getting the second monitor to work. Are there any settings I have to change? On my 2010 Mac Pro I am using the DVI out as the main monitor. Thank you |
Someone correct me if I'm wrong but I think this cable enables you to stream a display out of iMac to for example Mini DisplayPort projector, but not into it from your Mac Pro
Thanks, that makes sense.
Is there specific verbiage you think I should look for in a cable? |
Target display mode is as old as OSX.
The clue is; you connect the two, you have one mac running, you turn on the second mac, and press the key combination of that mac during startup. The second mac will be in TDM mode. Just a screen. Then go to system prefs to set them up. |
Thanks Ben however that didn't seem to work.
I did notice this on Apple's support page: https://support.apple.com/guide/mac-...ay-mh30822/mac "Note: Target Display Mode isn’t supported on iMac models with Retina display." I'm guessing that may be the problem. |
Also it seems, my advice about restarting is outdated. On the apple support page you linked to it clearly says you just need to hit command-F2 to make it happen. |
Speed up 2010 IMac ProTools 10 system | paullb1 | Pro Tools 10 | 4 | 10-19-2015 05:35 PM |
Pro Tools 11 w/ 2010 iMac 11,2 ? | kirkbross | Pro Tools 11 | 3 | 01-16-2015 08:23 AM |
Pro Tools 11 System requirements on IMAC 2010 | Badmadlad | Pro Tools 11 | 1 | 11-20-2014 10:49 AM |
Pro Tools 11 on iMac Mid 2010 | arsmetal | macOS | 9 | 07-17-2014 08:47 AM |
2011 MBP or 2010 iMac for ProTools 9? | ChrisFreeman | macOS | 7 | 04-12-2011 07:40 AM |
