Old 12-26-2013, 11:31 PM
avalonsutra avalonsutra is offline
Default Omnisphere GUI freezes in PT11
Hi, I was wondering if anyone else encountered these issues...
Whenever I launch an instance of Omnisphere in Pro Tools 11, its GUI will freeze sooner or later. The clicks and drags are still recognised but the UI doesn't redraw. The only temporary solution is to close/re-open the plug-in window. Then, after a short while the UI freezes up again. This happens all the time and only with Omnisphere (other thirdparty plugins I'm using don't freeze). Omnisphere is fully up-to-date.
Eventually, after a while of continuing this game, PT will crash, obviously due to Omnisphere.
I couldn't find any other info about this particular issue so far. My system is Pro Tools 11 running on Mac OSX 10.9.1, on a Macbook Pro 3GHz Core i7 with 8GB RAM. I'm using a Mackie Onyx 1640i as the audio interface (actually using an aggregate device with the Onyx and Focursrite Scarlett in it but the Onyx is main).
I've read elsewhere that on Mac disabling hyperthreading might help Pro Tools with some issues. Is this still even relevant with newer PT versions?
Old 01-28-2014, 06:24 AM
SOUNDDECISION SOUNDDECISION is offline
Default Re: Omnisphere GUI freezes in PT11
Same problem here....any fix??
Old 01-28-2014, 08:46 AM
Omnisphere no problem here on the system in my sig file. I've had session with upwards of a half dozen instances of Omnisphere on as many Instrument tracks and it's been cool. Now there are some patches that will stress my system. I only had one crash of PT11 but that was because I was trying to see how far I could push things before having it crash. Got to a dozen instances of Omnisphere when that happened.
Jack
QAPLA!
Old 02-14-2014, 02:22 AM
Becharax's Avatar
Becharax Becharax is offline
Same issue .. I did contact the technical support and they are looking into it :) I'll let you know their reply :)
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 02-14-2014, 04:58 AM
ClaudeM ClaudeM is offline
It started when I updated to OSX Mavericks. I've downgraded back to Mountain Lion and problem solved.
Old 02-14-2014, 05:18 AM
Becharax's Avatar
Yea but that is not a solution ... Spectrasonics should release an update and I think now they know .. :)
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 02-14-2014, 11:11 AM
Remember that those that live on the bleeding edge are doomed to get cut by it. If I were anyone that has a Mac with Mavericks I'd invest in getting Mountain Lion from Apple and wait until software houses have their collective acts together with supporting Mavericks.
Jack
QAPLA!
Old 02-14-2014, 11:27 AM
chanlon25 chanlon25 is offline
I've had the same problem - was able to stave it off by deselecting the little red button in the top right hand corner of Omnisphere. Let me know if that works for anyone!
Old 02-15-2014, 04:00 PM
Becharax's Avatar
Tried it ... Freezes occur less but still exist
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 02-15-2014, 05:14 PM
The target button should have nothing to do with the problem people are having. All that really does is allow having more than one plugin window gui open at a time.
Jack
QAPLA!
HTML code is On
Omnisphere 1.20 TimNielsen Virtual Instruments 5 03-09-2010 04:38 PM
omnisphere geeball Virtual Instruments 0 12-30-2009 09:23 PM
PT8 cs3 and OMNISPHERE reycantong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-06-2009 12:03 PM
Omnisphere DonaldM Virtual Instruments 4 06-17-2008 07:11 PM
