Old 08-10-2002, 02:57 PM
Steven Sena Steven Sena is offline
Default Change Sample Rate in HD?
Hello all,
I am trying to change the Sample rate in my 192 I/O, it's connected to (one) 96 I/O, I am using the 192 as the Loop master.
Trouble is under -Hardware Setup -Sample rate, it's 44.1 only...
Is anyone experience the same problem?
Any ideas as to a fix?
Thanks...
Old 08-10-2002, 05:21 PM
digimidi's Avatar
digimidi digimidi is offline
Default Re: Change Sample Rate in HD?
With Pro Tools HD, the sample rate is set when you create a new session. It is unlike with Mix how you can change it with the hardware setup or Session setup window. This is because with Mix hardware you only have 2 sample rates to deal with, 44.1 and 48. With HD, there are many more options so the sample rate needs to be set when you create a new session.
If you need to change an exsisting session or template session to a new sample rate, use the Save session copy in command under file. You can then tell Pro Tools what new sample rate you want and if there are any audio files in the exsisting session, they will be sample rate converted as well. Hope this helps...
Gil
Gil Gowing
Principal
Digimidi Technical Services
Old 08-10-2002, 06:33 PM
Thanks Gil [img]images/icons/grin.gif[/img]
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
Can't change sample rate Gabriel_S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-20-2012 11:43 AM
Can't Change Sample Rate jasonschwartz Pro Tools M-Powered (Win) 1 01-11-2007 11:13 PM
change sample rate of 96 i/o ronfinch Pro Tools TDM Systems (Mac) 0 06-15-2006 03:19 AM
how to change sample rate?? remains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-28-2002 04:38 PM
