unbalanced vs. balanced question: 8*Bus + 888\'s
I'm moving up to Mix and getting two 888|24's for use with a used mackie 8*bus.
I'd like to use aux sends as the inputs to my 888's as their freely assignable - however some of the aux send outputs on the 8*bus are unbalanced. The 888 inputs are balanced though... is it a bad idea to plug a balanced cable into the unbalanced aux sends? This seems like a newbie question, yet i couldnt find an answer to it searching this forum, nor mackie's online forum. Any help would be much appreciated! [img]images/icons/smile.gif[/img] -Evan |
Re: unbalanced vs. balanced question: 8*Bus + 888\'s
Evan,
I'd recommend using the 8 busses for one 888/24 and 8 of the direct outs for the other, running everything balanced. With this scenario you'll have 8 Pro Tools inputs that can be freely assigned and the other 8 fixed. Another thought is to run all the 888/24 inputs to a TRS patchbay mounted above the console, and use the Mackie's jack field as a patchbay, in which case every input would be freely patchable. With only 6 sends it really isn't practical to use them to feed Pro Tools. You also risk a lot of routing confusion/mistakes if you aren't religious about zeroing your console.
Michael Damon Composer/Sound Designer Virtual Productions PT Ultimate, i9-9900k, 64GB RAM, Gigabyte Aorus Ultra MB, Sapphire Radeon RX580, Windows 10 Pro, Fireface UFX |
To answer your question, though, if you customise your cables to be balanced/unbalanced, you could do it. It's something very common for connecting older processing units. You just need to make sure that the unbalanced end of the cable has the cold wire soldered to the ground wire at the post (ring to sleeve, in a typical TRS cable). Cheers, and good luck. |
I use a berhinger 8-bus this way. It works very nicely. I take external pre amps and feed them balanced into "line" on the mixer channels. I disable EQ on them. And balanced from group outs and bal. into 001.
Remember that you can return a recording signal to headphones directly from the Mackie and have no latency in HP, just remember to pull down the fader on the recording PT track.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
thanks for the replies everyone!
I also read the submaster part in the manual wrong - i was thinking they were outputs - totally missed the insert part. The submaster inserts are unbalanced - so I'm going to get a patchbay. Anyone have any recommendations? I'm guessing I need one that accepts the balanced to my 888, and the unbalanced patched out to my 8*bus. Any patchbay brand recommendations? -Evan |
Quick question about balanced v unbalanced cables | Dark N Dubby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-22-2010 07:36 PM |
Unbalanced to Balanced question | dividedsci | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-25-2007 08:02 PM |
Balanced and Unbalanced | Fishman1 | General Discussion | 2 | 09-25-2005 11:27 AM |
Dumb Question: Balanced or Unbalanced?? | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-06-2005 09:41 AM |
mic preamp balanced/unbalanced question | n.mathis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-28-2002 12:49 AM |
