Old 01-20-2017, 10:45 PM
allegro85 allegro85 is offline
Default Kontakt 5
Need assistance getting it to work with Pro tools. I have copied the extensions and everything into the Avid folder like all the youtube and google searches suggested, but Pro tools 8 still won't pick it up
Any help would be appreciated. I'm running Windows 7 64 bit
Old 01-21-2017, 12:29 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Kontakt 5
Is Kontakt 5 qualified for PT8?
I.e. When you installed Kontakt 5 did you install the RTAS version?
Daniel
Old 01-21-2017, 12:42 AM
YYR123's Avatar
Look here for more info.....
https://www.native-instruments.com/f...isible.256883/
Daniel
Old 01-21-2017, 02:58 AM
It did have the option for RTAS. Watched videos on how to route Kontakt 5 in Pro tools but not sure where to copy the extension to make it work. Tried to place it in the X64 Program Files and Common Files but still not detected
Can get Kontakt 5 in Finale, Sibelius and Finale but not Pro Tools which is my main DAW
Old 01-21-2017, 05:21 AM
What exact revision of Kontakt 5 are you trying to use? NI dropped RTAS support somewheres back in the K5.5.x revisions IIRC.
Jack
QAPLA!
Old 01-21-2017, 07:09 AM
YYR123's Avatar
Sounds like he is trying to make a hack work...no support but he is trying to manually move and install things....
Easiest bet is to just ask NI for the version that last ran RTAS and install it automatically
Daniel
Old 01-21-2017, 09:29 AM
Yeah - going back and re-reading his posts that seems likely. Elsewise the NI installer would have put things where it wanted and he's be able to see it in PT.
Jack
QAPLA!
Old 01-21-2017, 06:01 PM
5.5 version. Should be compatible with Pro Tools
Old 01-21-2017, 06:03 PM
Oh so the problem is that Pro Tools 8 just doesn't support it? That sucks. Would have made life so much easier music wise
Old 01-21-2017, 06:07 PM
YYR123's Avatar
You could always scour the net and search for Kontakt 4....if your dead set on using PT8
Daniel
HTML code is On
Kontakt 5 with 10.8.1 TimNielsen macOS 0 09-03-2012 11:38 AM
PT presets from kontakt 4 not opening in kontakt 5 table17 Virtual Instruments 0 02-06-2012 12:13 PM
Kontakt 2 Stand Alone vs RTAS, Kontakt vs Giga ryan de topanga Pro Tools TDM Systems (Mac) 18 05-17-2005 06:36 AM
Besides / NI Kontakt Lalaman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-20-2003 06:14 AM
