Old 02-28-2005, 11:59 PM
Knekor Knekor is offline
Default Stacked recording?
Hello
This probably is a stupid question but..
I've come from recording in Cubase and when I record a track in there and then record over that the takes are stacked on top of each other. So if I want I can easily pick up the first recording.
Is it possible to do in PTLE? If so how?
Appreciate all the help I can get.
Thanks
//Kenneth "Knek" Nordenmark
Old 03-01-2005, 12:37 AM
KingFish KingFish is offline
Default Re: Stacked recording?
Yes... the little arrows beside the track name in the edit window, provide you with all of your "Playlist" options.
Record a vocal on a track named VOX then click on the little arrows.
Select "NEW PLAYLIST"
the track will now be named VOX.01 and appear blank
record another vocal, and repeat the 1st 2 steps, until you feel you've enough takes for your comp.
every time you add a playlist, the drop down menu that appears when you click the little double arrows, will provide you with a list of playlists "Virtually stacked" on top of one another ie...
VOX
VOX.01
VOX.02
VOX.03
etc...
Create a NEW playlist... call it something like VOX.COMP
it will be a blank playlist.
now you can flip between playlists, auditioning regions, Copy a good section by highlighting and CTRL+C
flip to your VOX.COMP Playlist, and CTRL+V to paste.
this is one of Many different ways to comp a vocal, every engineer has their own work habbits.
Generally, I personally do NOT create a NEW Playlist... I take the "Best performance" and use it as my main Comp, only editing in from the other playlists, area's I'd like to Fix.
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 03-01-2005, 12:40 AM
wow! Got it, thank you so much
Recording timing / late recording issue resolved DAWgEAR Pro Tools HDX & HD Native Systems (Win) 0 07-17-2013 09:10 AM
low latency recording vs low hardware buffer size recording chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 01-27-2009 06:49 AM
Stacked or looped recording?? HELP! stevecarter Tips & Tricks 5 08-06-2008 04:42 PM
Feature Request-stacked mixer view Drew Mazurek Pro Tools TDM Systems (Mac) 1 01-08-2005 01:36 PM
PT 5.1 - Recording very lengthy narrative project.. ran out of recording disk space? Rockman-Songwriter Pro Tools TDM Systems (Mac) 6 04-16-2003 12:32 AM
