Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 09-23-2020, 03:18 PM
OverWorld OverWorld is offline
Default "AAE error 22 was encountered." What is error 22?
Upon importing drum tracks from Superior Drummer 3, this error began popping up with trying to do any playback at all. This is the first time I have ever seen this error, its also the first time I've tried importing drums since upgrading systems. Google searches only result in solutions for AAE Error 2 and AAE errors in general, not AAE Error 22. I'm hoping someone here can help me figure out what is going on.
iMac Catalina 2019 16GB
Pro Tools 2020.5
Old 10-30-2020, 05:29 PM
imajuscule imajuscule is offline
Default Re: "AAE error 22 was encountered." What is error 22?
Hello Overworld,
Today I encountered the exact same error : "AAE error 22", in the following scenario:
- import a wav file in a pro tools project ("copy on import" is disabled in my preferences so the wav file has not been copied)
- then, in the filesystem, replace the wav file by a shorter wav file with the same name
- play the protools project... the error is triggered while playing the wav file
It looks like this error means "the wav file is smaller than expected" : it's probable that pro tools remembers the size of the wav file from when it was first imported, and now there is a mismatch with the size of the actual wav file in the filesystem... or something like that (we would have to look at the source code to confirm this)
I hope this helps for your case! Maybe you had the same thing : maybe the drum tracks you imported got overwritten and protools was confused about this?
Cheers,
imajuscule
Error: " invalid utf-8 sequence encountered while trying to encode utf-32" SoundByLaura Pro Tools 12 7 09-20-2017 01:00 PM
recently I got " AAE error 38 was encountered" pm mastering studio Pro Tools 12 0 06-15-2016 04:55 AM
"Could not complete the import audio command because DAE error 35 was encountered..." Sean_tiburon macOS 1 02-29-2012 07:03 AM
"DAE error -13001 was encountered" topix Pro Tools M-Powered (Win) 0 01-23-2011 01:00 PM
LE 8.03 on Vista Home SP2 Startup, get error: "DAE error -6006 was encountered." anhughes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-09-2010 09:12 AM
